Installing 3.73's
Installing 3.73's
I purchased some used 3.73's with about 5k on them. I currently have a 01 M6 T/A with about 40k miles.
1. Will these just bolt right in, no need to buy anything else? (shims, etc)
2. What type of fluid should I put in the rearend with these gears?
3. I have no idea where any shops are around here that can correct my speedometer with LS1 Edit/HP Tuners or whatever...any other ways? I live in MA.
Thanks in advance,
Nate
Thanks in advance,
Nate
i just put in 3.73's and the stock shims ended up being optimal backlash, but i bought a basic install kit beforehand just to make sure....just make sure you get the preload on the pinion set to the right inch-lbs, inspect your u-joints on the driveshaft and all the bearings in your diff, after all that you should be set
i used valvoline synthetic blend gear fluid and limited slip fluid as well
my speedo is exactly 10mph off...i dont even use it anyway
I am interested in swapping my own gears as well. Where did you get the basic install kit from? and what did you pay for your gears?
Thanks
Thanks
Originally Posted by bowtie4life
i just put in 3.73's and the stock shims ended up being optimal backlash, but i bought a basic install kit beforehand just to make sure....just make sure you get the preload on the pinion set to the right inch-lbs, inspect your u-joints on the driveshaft and all the bearings in your diff, after all that you should be set. i used valvoline synthetic blend gear fluid and limited slip fluid as well my speedo is exactly 10mph off...i dont even use it anyway
Thanks
Thanks
I bought my 3.73's off a forum member for $100. I would like to know where to get the basic install kit as well.
