Will the Hooker 00-02 headers work on a '99.
I also have an LS6 intake was was planning on taking off the A.I.R. as well as the EGR so is that the only difference between the 00-02 and the 98-99's???
Thanks in advance.
Thanks in advance.
They will bolt up just fine w/o the emmisions equipment. I would also cut off the AIR fittings and have a patch welded instead of running block-off plates. This will give a cleaner look and you don't have to worry about those little fittings blowing out and breaking off.
they will work with the emissions stuff... you just have to bend the pipes around to work with the headers. you just have to be careful not to messup the tubes. it should be fine as long as air can still flow through it.
my headers are for a '99, and it worked fine for me.
