Possible to disable rear ABS?
I already took off the TCS module in my car, but I still have ABS and would at like to keep it in front at the very least.
Can I order a 9inch without ABS/TCS sensors and still get decend braking (abs in front?) wihout the abs inop light????
i had a 10 bolt in my car that had abs/no trac control..and it got swapped out to a 4 channel so i dont have abs in the back but i think the said that its still in the front..not sure though, i do know that the pedal pulses on its own when i brake hard..
Listen i brought this up and people though i was nuts.
Look in you Gm Service manual all ABS seams to be is a on/off signal no a mv value.
If i am right you should be able to go to the wiring harness and jump the pins four hi/lo to one of the front wheels. that in turn should turn off the light on the dash. I am going to try it soon when i get a chance.
i do not think it will effect the breaks because the PCM will still see feedback for the too sensors in the front.
What do you think?
What do you think?
What do you think?
What do you think?
