All Edelbrock Victor Longtube Owners: Install question...
I am confused by the y-pipe setup. I was sent 2 3.5" band clamps and 2 3" band clamps. It seems to me that I need 2 more 3.5" band clamps to complete the y-pipe.
Is this the correct y-pipe setup...as in are all the pieces in the right locations?
Looks like the right Y pipe for sure and yes it does look like you'd need two more 3.5" clamps. Or do those black extension pieces actually get welded to the header collector?
Originally Posted by xssive
Even still, why did I get 2 3" band clamps? There is only a spot for one to fit unless the other is used for clamping the Y-pipe to the I-pipe...?
You need a 3" band clamp for the driver side and a 3" band clamp for the I-pipe. The 3.5" band clamps are for the connections to the merge collector. When you put the system together you may want to invest in high temperature O2 sensor friendly RTV sealant to seal the connections.
Glen
Glen
Ttt...
oh and that y-pipe looks assembled right to me, my friend runs them on his ws6, i helped with the install.
Originally Posted by Bandit 1
i know this is off topic, WTF is 'ttt'
you dont need those black things unless you want to get it fabbed up, the y pipe slips right onto the collectors then you bolt it. pt your 02s right after the collectors in the Y pipe.
