LS6 intake Done!!
Old 10-07-2004, 12:43 PM
OnyxY2KSS's Avatar
Default LS6 intake Done!!
ok so i just finished and started it up just as it was beginning to rain, i didnt use the ls6 coolant lines (so for anyone that cant find the lines this is a good alternative) just grinded the chekerboard on the bottom. car idles great and pulls so much harder after 3000! the only problem i have now is...... TRACTION!!!!1!!1!11ONEONEONE
Old 10-07-2004, 05:52 PM
Hoodshaker's Avatar
Any pics or details about which areas you had to grind to get it to fit with the stock coolant pipes?
Old 10-08-2004, 02:04 PM
OnyxY2KSS's Avatar
well if i was to do it again i would just cut them all off because i found myself grinding then test fitting then grinding some more then fitting again.... ect... also cut out the green clips that hook the knock sensor wires to the coolant lines
Old 10-08-2004, 08:49 PM
Hoodshaker's Avatar
Cool, thanks for the tip. Looks like I need to warm up the dremel.
