Just installed h/c and 30lb injectors, need startup advice...
I just installed a set of AFR 205's, a Comp 224/228 .581/.588 @112las+2, and 30lb injectors on my 99 C5. I have LS1 edit and I have three questions.
1: Should I start it with the old tune -> runs well set for 28.8lb injectors.
2: Should I scale my IFR? I was thinking of multiplying what I have now by 120%
3: Should I alter my VE table for a better idle? Its stock now.
If I should do any of the above what would be your recommendation as to the changes. I'm not looking for a nuts on tune, just a ballpark to get me running ok until I get to the dyno in a week or so.
Are those SVO 30lb injectors? If so, they'll flow more than 30lbs with our higher pressure. If you don't adjust your IFR, you'll run very rich and even if you could get it running, I wouldn't risk the chance of washing out your piston rings. Scale your IFR.
Considering your cam, you should at least start with NoGo's VE scaling of 60% of 400, 80% of 800 and 90% of 1200.
Attached is a zipped Excel spreadsheet that should help you out (I wish I could recall the author to give them proper credit).
