How much seat pressure for a 2.02 valve and a XE grind cam
Old 10-09-2004, 09:21 AM
eb02z06's Avatar
Default How much seat pressure for a 2.02 valve and a XE grind cam
I'm just setting up my springs (Crane Duals with stripes) on my ported heads. I was wondering what kind of seat pressure is needed for a aftermarket 2.02 valve( not sure of the brand ) with a Comp XE grind. The specs on the cam are 228/230 .571/.573 on a 112. I'm hoping people with these springs can tune in. I believe Paul at Thunder recomended 145 at the seat with stock heads and valves. Thanks!
Old 10-09-2004, 01:01 PM
FASTONE's Avatar
How are you setting them up,installed ht. or are you measuring the seat pressure?145 lbs should be plenty,btw whats the rocker ratio??
Old 10-09-2004, 01:10 PM
FASTONE's Avatar
Man you"re making great hp with that combo!!!
Old 10-09-2004, 03:59 PM
eb02z06's Avatar
Stock rockers etc, I'm measuring seat pressure with installed height. My cranes on my AS heads were set up at 1.8 and they started to float-seat pressure was only 112. I went wth a 1.71 installed height and 140-150lbs. Thanks for the compliment.
