View Poll Results: Have you switched tuning software? If so to which?
Yes... i went from LS1 Edit to HP Tuners
19
40.43%
Yes.. I went from HP Tuners to LS1 Edit
0
0%
I'm waiting for EFI Live
11
23.40%
I switched from a handheld to HPT
10
21.28%
I switched from a handheld to LS1 Edit
1
2.13%
I haven't switched
6
12.77%
Voters: 47. You may not vote on this poll
Poll: Have you switched tuners?
only post if this applies to you... have you switched tuning softwares?
My Response:
I ran LS1 Edit since the get go... once a better solution was available I switched... i'm running HPT right now
My Response:
I am waiting for this one to materialize:
Dicks Electronics Real Time (Working-Prototype)
Interface: Ethernet RJ45 (10 Mbps)
Features
- Changing Data Parameters IMMEDIATELY in Real Time without nasty ECM hiccups (ie. restarts)
- Upload/Download ENTIRE Data/Parameter in just under 2 seconds
- High Speed Data Logging - 700 PIDs at 40 frames per second
- Download ENTIRE PCM (Program/Data) in just 10 seconds (Yes, all those 4194304 bits)
- Upload ENTIRE PCM (Program/Data) in 20 seconds (Verifies Program by re-downloading, so PCMs doesn't die on you)
- No more time consuming re-replacing of the PCM to reprogram
Capabilities
- Uses the highly popular TCP/IP protocol. Yes, your car even gets its own IP!
- Wireless connection possible using Wireless Access Points/Bridge (Feel like datalogging from the grandstand?)
- Even tune a car over the Internet!
- View your car's status via a webpage. (RPM, Coolant, Temp etc.)
Features
Capabilities
This is a dumb poll since I use Edit and have not switch. Please revise the poll and include a chioce for - No, I have not switched tuners.
Un-scientific polls are stupid; now I know why Bush2 and Kerry1 are tied. As Gore the mutt showed us last time it is not the popular vote that matters it is the state-by-state results that elect the white house guy.
