Drag Racing Tech - Who's running 10.5 or faster and how tall of a tire are you running?
Pro Stock John
10-10-2004, 10:58 PM
I went:
10.3@136
1.59 (spun)
28x10.5x15
3.50 gear
4300 stall
I wonder if I can hook my car on a 26 if I play with the suspension.
383LQ4SS
10-10-2004, 11:06 PM
I went 10.0 at 138 on 26x11.5x15 ET streets with a 1.44 sixty foot. Only suspension was the 12 bolt (with eaton posi) LCA's, QA1's, Panhard. Stock Tq arm and rear sway bar.
red90cobra
10-11-2004, 12:35 AM
10.35@132 1.5 sixty then 10.42@136 with 1.45 sixty spun with 28x10.5x15
z28racerlt1
10-11-2004, 08:21 AM
John,
Why do you want to go from a 28 to a 26. That seems like you are going backwards.
You are losing the front to back footprint of the tire that way.
ken
FastBlackTA
10-11-2004, 10:03 AM
I dont think a 26 inch tire would be the way to go with your setup. Didn't you make 700 rwhp with your combo? Shakedown passes on a motor I just rebuilt using the exact same crank that came with the car when it was new we went well in the 9's with a 28 inch tall tire and a 1.34 60'...still plenty left in the car. Your mph might come up if you get your 60 foot down....it did for me anyway.
Navy David SS
10-11-2004, 01:45 PM
10.49
128+mph
1.40 (best 60' - normal 1.41-1.43)
30x9x15
was 4800 stall (will be 4400)
12bolt with 4.30 gears
John why only 3.50 gears??? I wouldn't go smaller tires, I would go bigger gears. 3.50 will give a high mph, but 4.30 should help in the 60' and 1/4 et.
David
y2khawk
10-11-2004, 02:37 PM
28x10.5Wx15 here
I currently need less gear ;)
NA$TY-TA
10-11-2004, 05:00 PM
28x10.5Wx15 here
LESS??? arent you at a 3.70 rear gear now?????
y2khawk
10-11-2004, 05:13 PM
yeah, i need less numerically :)
Buzzing pretty high with the 3.7
Pro Stock John
10-11-2004, 05:50 PM
A 3.70 would be better for my goals but a 3.50 gets better gas mileage.
NA$TY-TA
10-11-2004, 06:06 PM
So Matt you going to go with a 3.50 rear gear or a taller tire??... 29.2"????? Now????
2001-WS6
10-11-2004, 08:22 PM
Hmmm... I don't see you hooking if you're spinning the 28s all ready for a 1.59 though.
I went:
10.5@129.5
1.45 (spun)
26x10x15
3.73 gear
SY3500 stall stretching to around 3,800
What are you spinning the motor to right now?? Have to keep the 140+ goal in line with the tire and rear gear. :D
Rick
8seclt1
10-12-2004, 11:21 AM
9.14 @ 152 with a 28x9 et street tire..
cablebandit
10-12-2004, 11:59 AM
10.45 @ 131
1.61 60' dead hooking 26x10x15 et drags
The Juggernaut
10-12-2004, 12:32 PM
I'm thinking of switching to 24" tires for gas milage and because I hook too good. ;)
y2khawk
10-12-2004, 01:15 PM
:jest: :jest: :jest:
The Juggernaut
10-12-2004, 01:27 PM
Only PSJ spins on a 28x10.5 and wants to go to a 26" tire.
Sometimes I wonder what he is thinking.
gator's 99TA
10-12-2004, 01:41 PM
cause he is a
:pimp:
bumpin_records
10-12-2004, 04:39 PM
hey y2khawk im interested in your combonation. I dont know if your into sharing combinations but yours suit me the best. i have a iron block 6.0 i wanna go twin turbo tell me when i looked at your headers they look stock. can you give me the info on your headers n all. It will be greatly appreciated. you can also email me at bumpin_records@yahoo.com thanks again
Pro Stock John
10-12-2004, 05:19 PM
How does your car look on the 24's Sean? Tyte?
The Juggernaut
10-12-2004, 07:29 PM
I haven't got them yet...but I bet it looks Pimp with my 5" spacers.
