Generation III Internal Engine - Removing crank timing sprocket?!?!
02NHRATA
04-06-2003, 05:30 PM
ok ok how do I get this sprocket off??? Replacing oil pump and going with SLP double roller timing chain and am held up with removing the old crank sprocket.
Thx
LS1swap
04-06-2003, 07:01 PM
You need a puller... None of my regular pullers would get behind it. So I used my harmonic ballancer puller ( like a gear puller but with four arms with slots instead of jaws) and caught it with the heads of three 3/8" carriage bolts. It came off pretty easily once I got it hooked. I haft to laugh. When I first saw the topic I thought you wanted to take off your reluctor wheel. I was going to say stop but then I read the post. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
BigBake
04-06-2003, 07:17 PM
Do you have to drop the oil pan to do this?
Argon Z
04-06-2003, 07:22 PM
i used my 3 jaw crank puller to get mine off
it is tought to get started but it comes right off.
DreamWeaver
04-07-2003, 01:46 AM
Thx finally got it off what a pain was the hardest part of the swaps - cept for cracking the housing but thats another story lol.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif"> Do you have to drop the oil pan to do this? </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">yes. Gotta drop the pan to remove the pickup tube off the oil pump.
Fastest 35th SE.
04-07-2003, 09:01 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by BigBake:
<strong> Do you have to drop the oil pan to do this? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Just have to pull the bolts on the pan and let it sit on the K-member. There is one 10mm bolt on the pickup tube, then the pump will come out.
