Lingenfelter specials
Old 10-11-2004, 09:02 AM
Jeff@LPE's Avatar
Default Lingenfelter specials
Check out our weekly specials!
LPE 3 1/2 aluminum driveshafts for 1990-2002 Camaro and Firebird, regular price $299.95, on sale till 10/15 for $239.95.
Supertubes for LT1, regular $159.95, now $134.95.
Don't forget to check out our other specials as well!
http://www.lingenfelter.com/lpefeatureditems.asp
Old 10-12-2004, 01:32 AM
The Dragon's Avatar
Concerning the driveshafts; obviously they're lighter than stock, but how much stronger are they?
Old 10-12-2004, 09:01 AM
pewterta's Avatar
can this driveshaft work with a ford 9 inch???
Old 10-12-2004, 02:57 PM
Jeff@LPE's Avatar
These driveshafts are direct replacement for the stock piece from 1990 to 2002 Camaro and Firebird. For you guys that have the aftermarket rear ends like the Strange, or the Moser 12 bolts, (I am not sure if it will work with your 9 inch) we have a conversion u-joint for the 1330 to the 1350 pinion yoke.
As far as strength, you have to consider torque more than HP, and how much it can handle the load (sticky tire vs hard launch in the higher torque range) don't forget wheel hop and shock loads! You will have a higher critical speed with this driveshaft over the stock steel shaft as well. But to answer your question, we have customers that have over 650 HP that use their cars for drag racing using this shaft with no issues.
Here is our description on our website:
Reduce unwanted driveshaft vibration and rotating mass by roughly 5 pounds over the steel LT1 and L98 driveshaft with this custom 3.5" high strength aluminum driveshaft that weighs only 12.3 lbs. This driveshaft also provides a much higher critical speed (maximum operating RPM) than the stock 2.5" steel shaft, the 2.75" aluminum 1LE shaft or even the 3" LS1 shaft. The stock steel shafts in the 1993 to 1997 LT1 cars are 2.5" in diameter. The 1988 to 1992 1LE aluminum shafts were 2.75" in diameter. The 1998 and newer aluminum LS1 driveshafts are 3.0" in diameter. The 3.5” diameter LPE driveshaft has a critical speed of roughly 11,000 rpm (over 50% higher than the factory driveshafts). This aluminum driveshaft is 3.5" in diameter and weighs 12.2 pounds. The U-joint centerline to centerline length is roughly 40-9/16”.
In testing performed by General Motors on our 3.5” driveshaft, this driveshaft did not show resonance (hit critical speed) until roughly 237 mph (tested in a 6 speed LT1 equipped F-body with 3.42 rear end gear).
The LPE driveshaft also includes an internal driveline noise suppression system and is high speed balanced to reduce vibrations. LPE recommends this heavy-duty driveshaft for virtually all high speed and racing applications.
Old 10-13-2004, 01:42 AM
Eiyse98ls1's Avatar
mhan.. i just got mines from you guys two weeks ago. why couldnt of you guys did this earlier? whats the next sale on.? i need to know before i go spending extra money.
Old 10-13-2004, 04:35 PM
botsigLS1's Avatar
What would the Shipping & Handling be on a drivshaft to Arizona, 85745?
Old 10-14-2004, 02:33 AM
The Dragon's Avatar
Excellent sales delivery and information I'll be ordering later this afternoon Jeff.
Thank you,
Christopher
Old 10-14-2004, 05:19 PM
Jeff@LPE's Avatar
$21.67 to 85745
Quick Reply: Lingenfelter specials
