Any way to delete cruise control for one-wire TB?
I have a 2000 SS with cruise-control. I want to clean up the engine bay and getting the three throttlebody-wires that cross the engine bay are part of my efforts. Is there any way to convert it over to the one-wire style like non cruise-control cars? What I'm really looking for is a write-up. Thanks- Mike W.
Originally Posted by Kevin 276
I removed mine and all you need to do is go to the dealer and buy a non cruise car throttle cable. It will run directly from the gas pedal to the T.B..you are done.
Originally Posted by SStolen
There are three wires total now. One wire will run to the pedal, so what other wire do you leave and how do you remove it from the motor? The motor is the black cylinder piece next to the AC drier right?
if you want to delete tcs and cc then all you have to do is purchase a throttle cable for a non tcs car, probably about $15-$20 for the single cable. If you just want to delete the tcs and still have cc then buy the throttle and cc cable for a non tcs car, cc cable is around $20-$25. You will need to pop the top off of the tcs module to disconnect the cc cable in order to have enough room to disconnect the other end of the cc cable from the cc module in the driver front fender area.
