My gains from LSX 90mm intake.TB and headers
Old, LS6 intake,TR ported TB and SLP 1 3/4 headers
New, 90mm LSX intake and TB, QTP 1 7/8 lt headers
Just a tad under 30 rwhp and 28 torque
GTP Iron 408,TH-400 4000 stall, 12 bolt with 3.73s.
Not bad, seems like the engine is breathing a little better. Now to get to the track and get some real numbers.
chris...I think you have more in it. I found the wideband wasn't tightened into the pipe correctly...probably making it read leaner that it was really was.
It read way leaner than my onboard wideband...
I think your car is still way too rich...get Jason's wideband in it for the track
Thank you again for your help.
Definately I nice setup, Chris!
I was lucky enough to be there the first time you fired her up.
All I can say is DAYUM!!! No wonder you pissed off the cops in OC
I had the cut outs capped, i was idling too. damned cop was being a richard cranium.
Wow, congrats. This intake seems to be very impressive. I'm sure some of it was from the headers but I would think only 10hp at the very most.
I switched from slps to grotts too, because of the ground clearance.
