11 Second Club Snake eyes are a good thing
11.95 114mph Bone stock 2000 LS1
Old 10-12-2004, 01:47 PM
10 Second Moderator
Torkman15's Avatar
Default 11.95 114mph Bone stock 2000 LS1
I finally broke into the 11s with my bone stock not even a LS6 intake LS1 motor in my 2000 Camaro SS at 3300#s with all suspension bolt ons cept rear shocks and springs. Running a 6 speed no less. Lotsa people were amazed at how the car looks and sounds so tame but leaves like a shark, (1.67 60ft) No way to post slips. Any one help me?
Old 10-12-2004, 02:26 PM
_HAVOC_'s Avatar
congrats, must of been some amazing weather conditions!
Old 10-12-2004, 02:56 PM
CAMAROonROIDS's Avatar
shizzits gettin deep over here
Old 10-12-2004, 03:33 PM
Race your car!
JL ws-6's Avatar
I'm calling on this one.....
Old 10-12-2004, 05:05 PM
10 Second Moderator
Torkman15's Avatar
Call it what you want but if you were there you would believe. I have a friend who was in Hot Rod April 04 pg 82 who helped me alot along the way and you wouldnt believe his car either but when all you see is tail lights and a 10.40 pop up on the boards you start to believe. Dave knows how to haul the mail with very little. Iv'e worked hard all summer and spent a load of money on susp and weight saving parts to run that fast without any motor mods just lid filter and LTs with a bullit. I ran 11.95 at 114.78 and next run 11.999 at 114.83 N/A. Remember I had a friend who had been there and done that coaching me every step of the way, Thanks Dave...Also Matt Harlan at Harlan Engineering (Y2KHAWK) who went 8.50 something at M9...yup you had to be there too!!! Very exciting racing.
Old 10-12-2004, 05:13 PM
10 Second Moderator
Torkman15's Avatar
Yup weather was almost perfect. Could get better here shortly. Thanks for not doubting me HAVOC I spent too much time and money for EVERYONE to just discount it and say B*&%$&!T. Clutch was a very limiting factor till I bought all new stuff (SPEC stage 4 and GM Hyds) and then went real fast.
Old 10-12-2004, 06:58 PM
SlickVert's Avatar
Great Job,
Sound like you spent your time doing all the right stuff.
What tires did you run and what kind of suspension mods?
Old 10-12-2004, 07:27 PM
Tally TransAm's Avatar
so you have a lid, LT's, exhaust, and lots of suspension work on your "BONE STOCK" ls1
ahh
nice times though
Old 10-12-2004, 07:29 PM
10 Second Moderator
Torkman15's Avatar
Originally Posted by 99RamairBob
Great Job,
Thanks, My tires I kinda fell into. A guy bought a set of 15x10 Bogart welded RTs and M/H Racemaster Musclecar tires 275 50 15 and decided not to dragrace a month later so he sold all to me for cheap. BMR k member, a arms, t/a and trailing arms. No name aluminum adjustable panhard, Moser/Strange/Eaton 33 spline 12 bolt, QA1 fronts w/QA1 drag springs. Still waiting to buy QA1 rear shocks and a bag. When I get money I spend it. All the traction aiding mods made my stock clutch go away real fast. Bought a new GM flywheel and all hyd parts and a SPEC stg4,put em all together and bam my plan came together...11.99s or faster by the end of the season with NO motor mods.
Old 10-12-2004, 07:34 PM
10 Second Moderator
Torkman15's Avatar
ahh
nice times though
I guess I should say stock engine, the rest of the car is aimed at low 10s, and Thanks!
Old 10-12-2004, 09:57 PM
RUQWIKR's Avatar
I am "working" as his unpaid consultant...actually, he stocks his cooler at the track better than I do. He's got various parts off of my car on it (axles, muffler, etc.).
I was out there in mine wanting 10.40's but a bad 02 sensor due to bad #6 & #8 exhaust valve stem seals took it out...was bogging off the hit of the throttle to "poor" 1.54 60's...normally 1.39-1.42...oh, well, it ran a "poor" 10.60 at 128.
Tom's got a lot left to do and still be streetable as he's on DOT's through the exhaust: I told him to go lighter brakes on the front, a good underdrive, change to an LS6 intake, raise the rev limiter up, swap in some race seats for those power leather ones, etc.
Take care. Dave
PS: Tom, I emailed you a couple of resized pics that you can host and attach here...my hosting site is down tonight.
Old 10-12-2004, 10:25 PM
1BADFNHuggerZ's Avatar
Great job, it is very doable, I have a friend with the following mods on his 2000 SS and he's been a best of 12.13 @111
LS1 intake
Hooker coated LTs
true duals w/ X-pipe & spintech mufflers
TSP lid
Ported TB
Descreened MAF
12 bolt w/ 4:30's
26" MT ET streets on 16" trans am wheels
Weight reductions:
No back seats
No A/C
Stock suspension
Stock torque arm
Stock LCA's
This car went a 12.89 when he bought it on radials bone stock, not even exhaust, it's just a factory freak.
Old 10-13-2004, 08:12 AM
10 Second Moderator
Torkman15's Avatar
Thanks huggerZ
Old 10-13-2004, 08:58 AM
Race your car!
JL ws-6's Avatar
O.K., I resind my BS comment. I was originally under the impression that this was a "stock" car with suspension done. Now that I see what you really have going on, I understand. Damn good job. If you don't mind me asking, what are you running, exactly? M6 or auto, gears, clutch/stall, what suspension mods, what's the weight of the car with you in it, etc. etc. I'm hoping to get my car into the low 12's with the power in my sig, you may have some stuff done that I should look into doing. I'll never have a real light car, as I wanna keepteh comfort items in, but the suspension, shocks, and whatnot may be useful.....
Old 10-13-2004, 11:36 AM
10 Second Moderator
Torkman15's Avatar
Less weight is the key to my sucess also having the weight removed from the nose helped alot. You can have a light car and with the adjustable shocks you can tune the road ride. M6 with new SPEC stg4 and new GM hyd parts w/drill mod 4.11 w/26 in tires QA1 front coilovers set on lowest setting, BMR K member and arms, connectors, torq arm. Factory interior yet but no back seat. The day I ran the #s the car with me in it was 3285#. I was having trouble leaving and shifting at the right RPM so Dave told me to get a Harlan LS1 specific 2 step and shift light, that helped me to find the SWEET spot to leave and shift at + its all stuff you can hide and dont hinder daily drivability. If you have cam/heads you can really benefit from a Harlan 2 step and light, it is plug-n-play simple to install. 3 wires for the light and 2 for the 2 step plus the wires that go to the coils. Good luck to ya, Tom
Old 10-13-2004, 12:34 PM
Race your car!
JL ws-6's Avatar
I was looking at the BMR k member and a-arms, that along with a lightweight battery setup like the one that Gomer did would probably save about 100 lbs out of the front of tha car, not too bad. Last time I went to the track, my car was 3630, but that's with my 265lb *** in the car.... probably not helping any. Now, the car has slp frame connectors, and once hte 12 bolt goes in, that's probbaly gonna add another 100 lbs to it. Even if I do the lightweight front suspension stuff, it's still gonna be pig heavy, because I refuse to gut it. I guess I'll have to throw an extra 250 RWHP at it to get it to where you're at. Oh well. Thanks for the info though.
Old 10-13-2004, 04:06 PM
10 Second Moderator
Torkman15's Avatar
I didnt think my Moser 12 bolt was 100#s more than the stock rear...I shoulda weighed em both when I swapped em...
Old 10-13-2004, 04:34 PM
_HAVOC_'s Avatar
Yes, I definitley believe it!
The 2 keys to Torkman15's success is his 60' (due to his 12 bolt and suspension mods and ET streets or what ever he used) and his race weight.
I did a 12.44 @ 112.83
with almost the same mods, !FRA, Long Tubes, True duals, Lid, pro 5.0 shifter, and an ls1 edit tune. and very minor weight reduction (3580 with me in it). this was under ideal weather conditions to.. now i ran my 12.44 with a 1.86 60' (on nittos) on a 100% stock suspension minus hte front sway bar.
now if i were to of matched his 60' of 1.67 I would of of ran about a 12.06. now add in the weight of his car (3285) compared to my 3580 and its easy to see how he ran an 11.95
Old 10-13-2004, 05:17 PM
10 Second Moderator
Torkman15's Avatar
When I mentioned my friend and (seeing eye dog) Dave Whitten pg82 April 04 Hot Rod mag I forgot to mention that Ronnie Duke pg85 same Hot Rod mag has helped me alot with parts (Hardcore Racing) and Ronnies tuner Dave Henninger put a super tune on the car when all I had was headers and lid (also Hardcore Racings Dynojet chassie dyno)... Thanks to both Daves and Ronnie for all your time and patience , Tom
Old 10-13-2004, 05:49 PM
your car isnt bone stock dipshit......you have long tubes thats a major bolt on
Quick Reply: 11.95 114mph Bone stock 2000 LS1
