View Full Version : LS2 intake ? for sdpc
wildta
10-13-2004, 12:36 AM
How does it compare to LS6 or a LSX ? Does it flow better than the LSX :confused: What is is this tb so saught after ?
p.s. Looks Nice !
Camaroholic
10-13-2004, 07:01 AM
It's $600 cheaper than the LSX and has a 90mm opening. You have to do a little work (fuel rails, extend MAP sensor) to make it work... But that $600 could be the cost of a nitrous kit. ;)
Mine should be here by Friday. ;)
Squintz Palladoris
10-13-2004, 08:46 AM
Mine will be here next week :)
Brad
Squintz Palladoris
10-13-2004, 08:47 AM
Have to make a brackett for your throttle cable brackett as well.
Brad
Danny2tek
10-19-2004, 08:32 PM
:werd:
WS6FirebirdTA00
10-21-2004, 10:27 PM
so what all has to be done to make this work, EVERY part needed, TB and all. cause im thinkin about gettin a cam and i figure why not get this intake since its so damn cheap. and where can i get it? and how long will it be cheap
Squintz Palladoris
10-21-2004, 10:41 PM
SCPC is selling all the parts you will need for around $820. That includes a Fast 90mm TB. You will have to Fab up a brackett for the throttle cable.
I hacked up my old ls1 intake and epoxied it to the intake.
I just need the TB now. I am waiting on funds for that.
Brad
U LUZ
10-22-2004, 12:11 AM
This Is Good To Know Since I Just Spent 1500.00 In This Piece Of Plastic...
screamin00ss
10-22-2004, 01:44 AM
does that 820 include injectors...if so what size are they...
Squintz Palladoris
10-22-2004, 05:02 AM
thats using your current injectors.
Brad
Camaroholic
10-22-2004, 09:42 AM
The $820 includes the LS2 fuel rails, which price out at about $129 or so. I opted not to go with the fuel rails, since I'll probably upgrade to some billet units anyway. I'm just going to hack my LS1 rails to "get me by" until I'm ready to upgrade the fuel lines & rails.
Squintz Palladoris
10-22-2004, 09:46 AM
I have 2 ls1/6 rails if any of you are interrested.
FWIW the ls2 rails are larger and they do hook up to the factory fuel line.
Brad
WS6FirebirdTA00
10-22-2004, 12:26 PM
for 400 bucks and just a little bit of imagination you can have this set up for the same price u can get an ls6 set up. just have the same tb. i have a real good idea on what to do so if someone has an ls2 they can give me some dimensions on i can fab up a trottle body adaptor with a bracket built in. or if anyone wants to let me borrow one so i can do this in the machine shop. this would be a great project for my design class next semester at unc charlotte lol
Squintz Palladoris
10-22-2004, 12:52 PM
You can come by my place n take any measurements you need. I am in Fayetteville, NC. Drop me a PM
Brad
WS6FirebirdTA00
10-22-2004, 01:48 PM
um, i would but i kinda lost my license haha. let me go home and look at my car and ill try and see what i need measured, shouldnt be much. just like the length and stuff. i seen a link with a whole lot of pics of the intake, does anyone know where that is now i cant find it
Squintz Palladoris
10-22-2004, 01:50 PM
Let me know waht you need measured. I can take some pics too.
Brad
WS6FirebirdTA00
10-22-2004, 04:33 PM
ok i need pics of the throttle body region, the length from the front bolts that hold the manifold down to the opening in the manifold where the TB goes, dimensions of the flat spot where the TB bolts up to. are the bottom holes the same as the ls1 tb? hmmm thats all i can think of right now if i think of anythign else ill let you know what im lookin for. ive got the bracket all figured out, it will look factory, when i get it made ill post some pics, as for the adaptor i drew something up but ill have to check all measurements first.
WS6FirebirdTA00
10-22-2004, 05:01 PM
um, 98-2000 do i need to change the coolant tubes ? looks like it has some clearance
WS6FirebirdTA00
10-22-2004, 05:03 PM
and those intake ports look nasty, they easy to clean up with a dremil?
Squintz Palladoris
10-22-2004, 05:10 PM
Yes you will need to get rid of the X coolant pipe and get the ls6 style coolant tube for the front and plug the rears.
Yes, I spent about an hour or so cleaning them up with a dremel tool.
Here are som pics of My "Factory Looking" Brackett
http://www.horsepowerjunkies.com/gallery/data/500/34520234013.JPG
http://www.horsepowerjunkies.com/gallery/data/500/34520234031.JPG
WS6FirebirdTA00
10-22-2004, 05:15 PM
damn that looks good, you have any pics of the other side? that was in line with what i was thinking if i was gonna have a separate bracket
Squintz Palladoris
10-22-2004, 05:34 PM
I will run take some n up load. Hold Please
Brad
WS6FirebirdTA00
10-22-2004, 05:38 PM
alright, how does the ls1 tb fit. do the bottom holes line up or no? does the top hold on the tb for the ls1 clear the top of the opening on the ls2 intake? and how did u get that tb thing on there? epoxy?
Nasty N8
10-22-2004, 05:48 PM
No the bottom holes are spaced a little farther than the LS1. A FAST style TB blots right on. This intake has no advantage if you stick with the stock TB. If you want to use the stock TB than use the LS6 intake it will be just as good.
Nate
Nate
Squintz Palladoris
10-22-2004, 05:54 PM
:stupid:
I am simply providing this info for those who want to make a brackett. I definately do not want a stock TB on mine. Hell I can probably put the stocker inside of this intake lol.
Here are some more pics
http://www.horsepowerjunkies.com/gallery/data/500/34523004446.JPG
http://www.horsepowerjunkies.com/gallery/data/500/34523004418.JPG
Squintz Palladoris
10-22-2004, 05:55 PM
http://www.horsepowerjunkies.com/gallery/data/500/34523004342.JPG
Hope that helps
Brad
WS6FirebirdTA00
10-22-2004, 06:02 PM
well i was just doin that for now until i coudl see what else would come out cause tahts a lot of money for a dman TB lol
Squintz Palladoris
10-22-2004, 06:12 PM
If you look around and make some Phone calls you can get a FAST TB for a good Price. Mine will be shipped next friday and I did not pay alot for that muffler.
Brad
WS6FirebirdTA00
10-22-2004, 06:14 PM
im torn, i dont nkow if i should get an ls2 or ls6 cause i see how you get better power then i see that you dont?! ahhh its making me go crazy lol. the ls2 does look good though and well it costs just about at much as an ls6 if i could get this idea to work out. so i have a bigger intake just incase i wanna go bigger in the future without wasting money. nate i know you said ls6 shoudl be good with a 232/234 but what is the limit where i should go 90mm? just if i have big cubes or what? and when you have a chance can you see from the front intake bolts to the front of the intake how far that is? the ls1 intake measured 4 inches if its much more than that i dont see it working too well
Squintz Palladoris
10-22-2004, 10:07 PM
You wont be wasing your money on an LS6 setup as you can sell it when you decide to upgrade.
You should be able to get an LS6 intake and a ported TB for 450 or so.
Brad
WS6FirebirdTA00
10-22-2004, 10:40 PM
my tb is ported right now thats on the ls1 intake. know anyone that wants to get rid of an ls6? like nate said i will keep my low end with the ls6 which in turn can turn better times seeing im in that range more i only see peak for a little
Squintz Palladoris
10-22-2004, 10:44 PM
mine is already sold. Sorry
Look in the parts for sale section or check with SDPC or any othe sposor for that matter.
Call KJ at SDPC I am sure he can give ya a good deal.
Brad
Nasty N8
10-25-2004, 12:10 PM
I have 2 New LS6 intakes for $350
Nate
P Mack
10-25-2004, 09:48 PM
So does anybody have a complete ls2 conversion yet?
