beertestr
10-13-2004, 07:33 AM
I took my car to Grattan Raceway (www.grattanraceway.com) yesterday for some open track time, and learned quite a bit about my GTO.
1- The stock BFG's can't take open tracking. I chunked the tread pretty bad on the fronts.
2- More front brakes are a must. I was running PF pads for a C5 (there is another post on that), but the rotors were not up to the task, and I boiled the fluid. Time for a brake upgrade.
3- The car need more front camber, or more camber gain. I have seen worse, but I chewed up the outer two tread blocks on the fronts. I another degree might help the problem. As far as body roll, it was pretty good for stock..
4- As usual, the stock car is set up to understeer. This sucked, and it took some hard lfogging to get the tail to come around. I think the posi needs more pre-load too, as the inside can get broken loose pretty easy..
5- Run the oil level 1 quart high. I had the oil light come on once on a hard right hander with hard suspension inputs. I tossed in an extra quart, no probs..
The rest of the car RAN AWESOME!! I got 100 miles out of a tank of gas, 6 mpg indicated on the DIC :eyes: . I had a Thermocouple in the oilpan, the sump temps never got over 275F, without any external oil coolers, but it's good to run synthetic. Engine temps NEVER got above half, on a 65 degree day. I was running with some guys with A-sedan cars. If I could get the car to corner a bit better, I could out lap them, no prob. Sure, I had 5.7L, they had 5.0L, but they had slicks (maybe very worn R-compound treads) and weighed 1000# less.
Next time I go back, I will have:
- More front camber
- Better tires
- Better brakes
- I'll probably leave the passenger and rear seats at home, and the spare tire in the pits.
-Maybe a gell cell.
- I wonder if the BMR strut tower brace really does anything, I'll might try it out.
- More front camber
- Better tires
- Better brakes
-Maybe a gell cell.
