Admins: Feed The Hamsters!
Admins: FEED THE HAMSTERS
They're not running on their wheels nearly fast enough.
(to webmaster)
Is the site being hit by the lastest barrage of google spider-bots? The local F-body club site had almost two hundred of them on it at once a few days ago... its insane
Any insight?
(to webmaster)
Any insight?
I did have a lot of trouble getting on the site many times yesterday. It also seems unusually slow also. I kept getting disconnected, and that never happens. I would at times get website unavailable, the wesite may be having difficulty or is no longer available.
its been happenin to me on and off for a few days now. a few ppl i've talked to apparently have had similar issues as well. "server not found" errors popping up. they are usually resolved in 10-15mins tho.
I'm starting to wonder if its a network issue somewhere, rather than a server issue.. I haven't had any slowdowns that lasted more than occasionally hitting the 30 second window when some clean-up events run (four times per day). Even then, you shouldn't have more than a few second delay in loading a page. Normally page refreshes shouldn't take more than a few tenths of a second if your connection is fast enough.
Can you guys post in here the exact time (with timezone) so I can try to correlate it with site stats? I'd like to see if its a network congestion issue or a server problem. Can't have LS1Tech being slow, you know
