New LS1 Owners - Newbie Tech - UMI Short Shifter Handle
hitmeoff
10-13-2004, 03:46 PM
Just got it today and installed the bastard on my car...
Gotta say, this thing freakin ROCKS. Shifts are soooooo ridiculously short now, really worth it.
At only $20 bucks, no one with an M6 should be without it!!
Brandon Boomhauer
10-13-2004, 04:26 PM
is it angled any closer to the driver?
i want to put a Short throw on my hurst, but dont want it angled any....
msbz_ls1
10-13-2004, 05:16 PM
i would get one..but i have an a4 man :(
01formula6
10-14-2004, 06:40 PM
Does this shifter let in extra noise from the transmission like some of the other short throw shifters?
jaberwaki
10-14-2004, 07:27 PM
not like i could hear it over the cam,headers ory pipe to cutout, or the hum from the 9" or the vibration from the solid mount spohn tq arm..... :jest:
i guess some people just like noise :drive:
2w0s060
10-14-2004, 08:01 PM
A shifter it self such as a Pro 5.0 may increase road noise, mine did. But just replacing the handle will not.
hitmeoff
10-15-2004, 02:37 AM
Yes its actually VERY angled...so much so that I really dont wanna use my Hurst knob, and looking into getting a ball knob instead. But the short thorws are awesome, I love it!
hitmeoff
10-15-2004, 02:39 AM
In fact heres a pic of what it looks like.
All u get is a the handle, 2 bolts and 2 washers, so u can see the angle of the handle as it attached to the shifter:
http://www.umiperformance.com/images/2105-2.jpg
hitmeoff
10-15-2004, 02:40 AM
Actually, I think it does. Ive noticed alot more noises lately, but it could also be my clutch goin...for the last week or so I havent been able to chirp :huh: :mad:
2w0s060
10-15-2004, 07:10 AM
Its impossible for just that handle that make any road noise, the ONLY way it could is if your boot was not installed correctly and you have alittle noise coming through there. Otherwise the handle itself has no way to increase noise.
demonspeed
10-15-2004, 03:09 PM
The only way it could is the factory hanlde has a rubbler insolator in it. It would be so minimal that I can't believe anyone would complain about it.
Oh well... another happy UMI handle customer here too :)
02blackws679ta
10-16-2004, 09:45 PM
thats exactly it...the rubber isolator on the factory shift stick must muffle out some of the tranny noise because when i put my lou's short stick in there was an obvious difference in the noise right away..i mean its not like its SO loud and annoys the shit out of me or anything, but they are noisier than the stock shiftsticks
Full-Force
10-16-2004, 10:02 PM
i have the B&M and I just cut the stick that came with it down by 1". I think it may have messed up the geometry of it or something because it is harder to shift and feels like Im having to pull it back farther. If I had it to do over again I would have cut it 1/2". The B&M handle acyually curves toward you and then back straight up. I think its curved too much toward the driver.
Its not just noise, but vibration when you put your hand on the knob with aftermarket shifters. Stock shifters are like butter compared to mine.
99huggerorangeZ
10-16-2004, 10:25 PM
where do i get this umi shifter handle??
David 2002 WS6
10-16-2004, 10:49 PM
To install this shifter handle do we first unscrew the shifter knob, pull out the leather shifter boot, remove the two bolts, remove the old shifter handle - and then do everything again in reverse using the new shifter handle?
I checked Install University (http://www.installuniversity.com/install_university/support/installu_documents.htm) (Transmission category) and they describe removing the whole center console and screwing around with the parking brake handle. Doesn't this seem like overkill for a shifter handle swap...?
camaro99z
10-16-2004, 10:55 PM
The write-up on Install University is about replacing the whole shifter. All you should have to do to change the handle on the stock shifter is take the leather boot off.
hitmeoff
10-16-2004, 11:20 PM
I had to take off the whole center console to get my ratchet in there to unscrew the bolts to the original handle. I didnt have a big long wrench to do it, if u do then you can use it without having to take off the console.
But yea, take off the knob, the boot, take off the original handle, then go back, put the new handle on, the bolts, the boot, and finally the knob.
Gloveperson
10-17-2004, 01:04 PM
Looks very similar to my JRS, except the base is A LOT beeffier.
-Todd
2w0s060
10-17-2004, 05:24 PM
Here ya go
http://www.ls1tech.com/forums/showthread.php?t=219830&highlight=umi
or...
David 2002 WS6
10-17-2004, 05:47 PM
Thanks for the replies, camaro99z and hitmeoff! :cheers:
v DaN 02
10-18-2004, 03:42 PM
where can you purchase the umi handle?
2w0s060
10-18-2004, 09:17 PM
Just look at my last post, about 2 post before yours and you will see :)
David 2002 WS6
10-19-2004, 08:15 AM
where can you purchase the umi handle?If you are referring to the shift knob, I think a popular choice is one from MBA (http://www.mbaproducts.com/interior.htm).
XtrmLS1spd
11-08-2004, 10:19 AM
how is going into reverse with the UMI?
demonspeed
11-08-2004, 01:40 PM
No different then it was with the stock shifter. You'll have no problems at all.
David 2002 WS6
11-08-2004, 07:12 PM
Before driving in traffic the throws between the gears with the original shifter stick were so long that it was like rowing a boat. Not any more. With the UMI Short Stick it is actually easier to shift between the gears, including shifting into reverse. :)
cueball
11-08-2004, 11:09 PM
:stupid: if it aint noisy, it aint workn.
:jest:
