True dual setup with one muffler.
I`m going to run a true dual setup over the axel very soon and want to keep a stock look from the rear of my Z. I saw that Magnaflow has a dual/dual muffler that has 2 inlets and 2 outlets that has a straight through X pipe built in. Are there any companys that make a dual/dual straight through muffler without the X pipe that will look stock on my car. Keep in mind I want to look stock but not sacrafice performance. I may just keep the 2 bullet mufflers on the H-pipe but I have had the Troopers pull me over with my cut out with stock exhaust and cats. Thanks for any help.
I think anything but a race muffler will not yeild as good of a flow. It would be a waste of money to run true duals into a catback exaust. You could still run true duals over the axle with two race mufflers and have your stock tips welded on. If I wanted to look stock that is what I would do.
Originally Posted by CrvnTransAm
The reason stock DOHC mustangs sound good is they have room for actual mufflers. If you want a true refined dual sound definitely buy a Mustang.
Did he really say that
How about you buy the mustang and ill blow by you while your listening to your exaust
On a serious note, I have yet to hear any mustang sound as good as 3" sweet thunders with an X pipe.
!LS1 11 Second Club
Routing both pipes (2.5" max) over the axle on the passenger side is the way to go.
If the muffler already has an X, you don't need another X-junction. But then again, the muffler's X would be so far downstream that putting the first X may not be a bad idea.
Originally Posted by ninobrn99
i know what muffler your talking about..p/n:11386. i dont think its a bad idea. this is what your talking about doing right??
Originally Posted by 777
i don't think anyone has actually...haha...he just wanted it to look stock..why? i don't know...it would be more than obvious that it isn't stock when you crank it up or drive by someone
!LS1 11 Second Club
Originally Posted by al
Actually thats the type of muffler I`m looking for. Is that a magnaflow. That is really straight through without the X built in the muffler.
The exhaust wouldn't cross flow like that. That muffler is meant to be used as 2 in, 2 out on the same side.
1 Post
Originally Posted by SouthFL.02.SS
This diagram has a major flaw.
