Not the rocker, now what?
Old 10-14-2004, 07:19 AM
flyingguy001's Avatar
Default Not the rocker, now what?
I have a 99' camaro SS with a m6 and about 70,000 miles. Found a needle bearing after the oil change. Thought it was probably from a rocker. I took off the valve covers and took off all 16 rockers and inspected them. They all seem to be fine. Now, I only found One needle bearing, even after two oil changes. What do you fellas think needs to be done from here? thanks brian
Old 10-14-2004, 08:46 AM
SAM98WS6's Avatar
are you the original owner...could have been changed before...maybe check the service history if a dealer did it.
cant come from anywhere else.
junk the stock ones while they are out...
Old 10-14-2004, 11:13 AM
I am not the original owner, but i have had the car since it had 20,000 miles on it.How do i check the service history? So its not gonna be a lifter bearing? And what kind of rockers should I get?
I know lots of questions, but i appreciate the help.
Old 10-14-2004, 11:17 AM
Boostaholic's Avatar
Lifter could have come apart, lifters have the same style needle bearings in them I believe.
Old 10-14-2004, 11:23 AM
technical's Avatar
It's not your lifter. They don't have needle bearings. If the pin came out, your motor would be gone.
Maybe the rockers had been replaced and that needle is from one of the old rockers.
