Valve retainer question, those with 1.4+ springs please?
I am installing 977 springs on my car which are 1.4+" diameter springs. I have the comp cams 730 titanium retainer which is a 10 degree lock retainer for springs from 1.43"-1.50". My question is I know ls1 valve stems are 8mm which translates into .3149". I saw on comp cams website that they offer a 10 degree lock for .310" stems. This lock will work right? 49 ten thousanths is really very minimal difference.
The reason I ask this is they actually offer a retainer which is setup for the seven degree locks and some of the dimensions are slightly different. Thanks.
Originally Posted by Unaffiliated Racing
you can't use those retainers or locks. You need to use a 776-16 retainer and 623-16 lock or a stock lock
Thanks,
Brian
Thanks,
Brian
Why, I need reasons. It makes logical sense that this shoud work. Is there clearence issues, valve lock to stem issues or what. I know the part number for the ls1 retainer for 1.43-1.46 valve springs but need to know if the 730, which will fit this range of springs, will work with a 10 degree lock setup for 8mm+.315" valves.
the LS-1 stuff is metric..the part numbers you have are not. The LS-1 uses a radial lock..the only one Comp has is the 623-16..the olny retainer that fits your application that works with that lock is the 776-16
