General Maintenance & Repairs - LT1 Air Pump
View Full Version : LT1 Air Pump
95camaroz28
10-15-2004, 08:54 AM
I keep blowing out my air pump fuse and im not why if i remeber right wasnt there a recall on some thing with the air pump??
curlyws6
10-15-2004, 11:44 AM
Yes, there was a TSB on this problem. Drop me an email and I will see if I can run down the TSB from the dealer which I scanned into a Word document. I have officially ended all my AIR problems with my long tube install :devil: .
95camaroz28
10-15-2004, 12:29 PM
Tsb???
95camaroz28
10-16-2004, 09:12 AM
O ok give me your email and ill drop you one. thanks
TwoFast4Lv
10-16-2004, 10:46 AM
There was a free update from gm. Was new air pump and wiring/
IF I remember right you can just un-plug the air pump it self and it may not send a code.
It has been a LONG time. Mine was done under factory warranty years ago. I still have it all some where...sitting in a box :D
Cerwin Vega Fan
10-16-2004, 01:41 PM
I tried unplugging mine and the SES light comes on.
TwoFast4Lv
10-17-2004, 01:20 AM
Like I said it has been a while. you can disconnect some thing and it will disable it but not set a code. Might be a good I dea to dig through the LT1 Edit achives ;)
