motor oil
Old 10-15-2004, 10:09 PM
ws62001ta's Avatar
Default motor oil
what engine oil do yall use?
Old 10-15-2004, 10:21 PM
skippytheloon's Avatar
oil+catback=busted block? I'll tell you what I use if you explain your title.
Old 10-15-2004, 11:07 PM
Danny2tek's Avatar
Old 10-16-2004, 12:56 AM
cyphur's Avatar
wtf, mate?
Old 10-16-2004, 01:14 AM
LS1LT1's Avatar
Lightbulb
It's true, if by chance you were to ever be using Valvoline 10W-30 and also happen to have a Borla cat back with all the plates in place on the car then yes, you can crack your block ...I thought EVERYONE knew this.
Just kidding.
Old 10-16-2004, 01:20 AM
NLang's Avatar
Oil has nothing to do with your busted block. Oil doesn't break things. It's KY for those moving parts...I use Royal Purple's R21 (close to 5W30), but it's over $8 per qt. Mobil1 synthetic is probably the best off-the-self you can get. It's around $4.50. 5W30 seems to be the best all around for these cars depending on your location. There's a reason a lot of us have 'Mobil1 5W30' stamped on our fill caps. It's recommended by the engineers that designed these motors. Use it...
Old 10-16-2004, 01:40 AM
ws62001ta's Avatar
wer sup to use 5w30????
Old 10-16-2004, 01:41 AM
ws62001ta's Avatar
i live in texas does that matter, lol im running 10w30 so do i need to change to 5w30?
Old 10-16-2004, 01:48 AM
cyphur's Avatar
check out my loc.....i have that stamp on my fill cap and a little metal plate...both sayin Mobil 5W30 Synthetic on it......thats what goes in my motor. royal purple is also great stuff so i've heard.
Old 10-16-2004, 01:53 AM
NLang's Avatar
Royal Purple is excellent stuff, but after paying for 6qts of it you feel like kickin the cat around a bit...
I use 5W30 (close to it anyway) right here on the gulf coast. It's just as hot here...
Old 10-16-2004, 02:09 AM
LS1LT1's Avatar
Thumbs up
I used to use to 5W30, then switched to 10W30 but will be putting in 0W40 soon (as per the ever knowledgable 'oil guru' Patman's suggestion), all Mobil 1.
If cost were no object I would probably go with Redline or Amsoil.
Old 10-16-2004, 02:17 AM
NLang's Avatar
A tad too thick @ temp for me...
Old 10-16-2004, 02:31 AM
ws62001ta's Avatar
so do you think i am running to thick of an oil? does this hurt my HP? or take away anythng from the car?
Old 10-16-2004, 02:54 AM
LS1LT1's Avatar
Lightbulb
No, actually I think he meant my new choice (the '40' part of my 0W40), nothing too thick about any of the 5W30 synthetics.
The reasoning behind using a Mobil 1 5W40 or 0W40 is that their weights tend to run a little bit thin (40 is more like a 30) in some cases.
Old 10-16-2004, 04:22 AM
Patman's Avatar
By far my favorite oil for the LS1 is the German made Castrol Syntec 0w30. I just posted the best oil analysis report yet for an LS1 when I used this oil in it. Very impressive stuff!
Old 10-16-2004, 04:29 AM
LS1LT1's Avatar
Thumbs up
Old 10-16-2004, 07:15 AM
SScreaminDemon's Avatar
I've only heard good responses about the German oil, where can I get some?Never seen it in the stores or anything.
Old 10-16-2004, 09:45 AM
cyphur's Avatar
You can find it around. Different chains carry it.
http://www.castrol.com/castrol/loadD...ategoryId=3240
Thats off Castrol's website. You give them the town and zip, and they give you the closest retailer.
Old 10-16-2004, 02:36 PM
CamTom12's Avatar
I use Castrol GTX 5w-30. Been using it since my Rx7 days and it runs great. Nothing beats synthetics, but I change mine ~2.5K, so running synth is a little pricey for me.
Old 10-16-2004, 03:48 PM
Ackattack1's Avatar
I switched from M1 10W-30 to 0W-40 and my oil consumption has went away (not that I was using a lot) I think one reason "the engineer" at GM say to use 5W30 is because it may get you a little better gas mileage. From what I've read, the M1 10W-30 offers a little better wear protection than the 5W30, and is a thin 10W30 anyways.
