MAC Header pictures needed.
Originally Posted by John_D.
Any particular type of shot? The y-pipe? Clearance around the k-member? Clearance around the floorboard? Location of the cats?
And if possible, one from the top of the engine bay.
-Todd
I don't have the stock k-member. I can try to get a couple of shots showing the location of the cats and the floorboard.
The view from the top is just kind of ordinary...
-Todd
Here are those pics. I meant to take them last night, but got tied up.
The first one is from the passenger side. It shows the y-pipe, the tunnel brace (slp driveshaft loop actually), and both cats.
The second one is from the same location, but with the camera pointed more toward the front of the car. You can see the bellhousing and a little bit of the pan under than auto trans, and both cats.
The last one is from the driver's side. It shows the driver's side cat, and the pipe coming out of the back of it. There is about 1/4" of clearance at that spot about 4-5 inches behind the cat.
-Todd
