Problem !! Help needed
I just got done building a motor 4 my car but I have a small problem. The driver side plugs look fine but the passenger side foul out. Any ideas ? So far im going to check the wiring that goes to the coils any other ideas ? I didnt do a crankshaft relearn could this cause this ?? Thanks for any help, Nathan
Moderator
Log the front O2 voltages, B1/B2 injector PW, STFT/LTFT and
see if there is anything you can dope out from that. Then
have a look at misfires-current PIDs for all 8 cylinders to see
if you have any clues there.
