Difference between at 402ci and 408ci?
Originally Posted by MeanWS6
What are the differences in spec's between the two motors? Crank, rods, pistons, bore?
//stroker newbie//
//stroker newbie//
Originally Posted by Chris@AP-Engineering
Generally bore is the only difference. Between 4.000" bore & 4.030" bore, that's what the difference is between the two.
Block needs to be sonic checked to make sure, and I think most 6.0l blocks are too thin to safely go .060, I think that .040 is generally accepted as the maximum "safe" overbore. IMO, stick with the least overbore that you can (.010 or .020), makes the block stronger, allows for future rebuilds (if necessary), and there is probably no measureable power differencs between a 402 and a 408.
Shawn
Shawn
