MS3 cam go wrong?
Old 10-19-2004, 06:59 PM
ws62001ta's Avatar
Default MS3 cam go wrong?
ok i have been looking into this new magic stick cam, freaking awsome!
1..but if i were to throw that cam and springs,push rods, would i have any problems with the stock oil pump?
2.. and would that cam be to much for my stock chain?
3.. I also see that MTI has around the same lift as MS3 but on MTIs web it recommends a way bigger cubd engine. so is this MS3 ok for me?
4.. and also with this new setup and tune will i pass smog? thanks skeeter
Old 10-19-2004, 07:06 PM
mikes02ls1's Avatar
1. I have stock oil pump with 44,000 miles on it, no problems at all. 50psi at idle.
2. Again I have stock timing chain with no problems.
3. I love this cam, I put down 416rwhp with 3.42 gears now with 4.10 it may be a little lower will see.
4. If your emissions is just plug into the OBD port then you will pass but it has to be tuned.
Old 10-19-2004, 07:18 PM
ws62001ta's Avatar
thanks man! i was stressing finding a badass cam that i cant buy just b/c of gay @ss smog. skeeter
Old 10-20-2004, 04:39 AM
TVWilkes's Avatar
I do not see any problems with you running the MS3.
Old 10-27-2004, 01:13 PM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
It works really well if you have some converter to back it up
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 10-27-2004, 02:13 PM
xfactor_pitbulls's Avatar
Swap the chain............Too cheap a thing to do that can save you a world of pain. IMO
Brandon
