ok to start engine w/ motor mounts unbolted???
im puttin my new oil pan in tomorrow, and i wanna know if i can start the car up before i rebolt up the k member and motor mounts...cuz if somethings wrong and i have to take the pan off again, i dont wanna have to drop the k member and undo the motor mounts all over again. by the way, i only took out the 4 bolts that hook the motor mounts to the k member....so the engine is still hooked to the mounts, but the mounts are not bolted to the k member. i have the engine jacked up now...so should i bolt up the k member, lower the engine onto the k member, and try to start the motor without the mounts bolted to the k member? would that be ok, or would the motor try to shake all over the place??
Yes its ok, it is less ok if you have a big cam or something where it will shake a lot. With your stock motor it will be fine
But it wouldn't hurt to bolt it down either, it only takes a few minutes to get a bolt started on each side.
5 seconds??? sorry but there is one or two on each side that were a bitch to get to even with a wrench....much less getting my hand back there to get the bolt started.
there is no nut....i only unbolted the motor mount from the k member. i left the bolts from the mount to the motor in place as well as the through bolt with the nut on it. i wouldnt have been able to get the through bolt out w/o takin the ac **** out.
All you have to do is remove the single long bolt that attaches the motor mount to the engine to k-member pedesetal on each side. The motor will then be able to lift off of the pedestals.
This is how I did it on a friend's car. No need/point in removing the entire motor mount off of each side of the block.
