Cars sticks at 2K idle when moving
As said above. I think it is my throttle body doing it. The guy that had it before me drilled it out for a 112 LSA mine is 114+4, but a pretty high duration 228/232. If I totally epoxy fill the hole, does that sound like it will knock out the problem? Or could it be something else? I am tired of coasting to stoplights with the engine spining like mad. Especially past a cop. Ideas?
Brandon
Brandon
Brandon
Brandon
Moderator
If it idles low once stopped but high when rolling,
that is probably some combo of throttle cracker
and idle airflow settings. If it settles down at a
dead stop then there's a chance that just tuning
will fix it.
will fix it.
Originally Posted by Shaner
Either your blade has been drilled to big for your car or it could be the idle set screw could be set to high. (or a combination of both)
Brandon
