What is the best way to route the wires to a shift light to the vent?
Got my new shift light in and just was wondering how people are routing the wire to the vent from the computer under the hood.
Looks like there is a plug under the computer and then from there to the glove box possibly and then to the vent?? Is there an easier way??
Thanks for all and any info.
STF Veteran
Remove the two 10mm bolts holding the PCM in place.
You will see a rubber grommet with wiring passing thru the firewall.
Make a small incision with an exacto knife.
Pass your wire thru the hole, and route it along the trunk of wiring with the loom on it.
Route to the destination of your choice while observing the wiring will no chafe or pinch on anything.
Secure it along the way using ty-wraps.
