Dynamometer Results & Comparisons - AFR 205 / G5X-3 Dyno Results....
View Full Version : AFR 205 / G5X-3 Dyno Results....
Tony Mamo @ AFR
10-21-2004, 11:34 AM
Another thread from the Corvette Forum...
This set-up would be approaching 500 RWHP with a FAST 90 and an electric WP....
Check out the link
http://forums.corvetteforum.com/showthread.php?t=929941
InsomZ
10-21-2004, 11:44 AM
awesome results! :) seems to be a potent combo
Damage Inc.
10-21-2004, 11:45 AM
Wow, he doesn't even have the 90mm setup yet! Were those heads milled at all or were they just out of the box CNC heads?
verbs
10-21-2004, 02:18 PM
What compression would that leave his heads at being milled .040? (according to his sig?)
Badass results BTW!
MUSTANGEATER
10-21-2004, 02:36 PM
Very Nice results. Any word on the 225's?
Louis
10-21-2004, 02:45 PM
Its right at 11:1,
Damage Inc.
10-21-2004, 03:12 PM
Was there any flycutting involved? I'm assuming a stock piston and bottom end.
Louis
10-21-2004, 03:38 PM
Yes, Flycutting was necessary. 75 thou to be exact.
CATransam
10-21-2004, 05:30 PM
afr heads are a custom casting, not a machined stock head.
SouthFL.02.SS
10-21-2004, 05:38 PM
Very nice results. Congrats.
Damage Inc.
10-21-2004, 09:16 PM
Louis, what custom piston would you recommend for a shortblock with 225cc AFRs and your nasty cam. Thanks. Is 2cc relief enough?
Fernando
52172
10-21-2004, 10:56 PM
kick ass numbers!!!!!!!!!!!!!!
ClarksZ06
10-22-2004, 12:44 AM
Thanks Tony for posting the link. I'm not on the boards all that much.
The car is a real screamer. I couldn't be more happy with the results, considering there is still alot more potential in it.
The car drives great. I can easly drive it everyday.
Big thanks to LG for the great parts and Speed Inc. for the great tuning.
riddler
10-22-2004, 01:33 AM
Dang those are some good numbers :thumb:
Pro Stock John
10-22-2004, 10:17 AM
... And the combo was dynoed at Speed Inc. so all in all very fair results.
Chris81
10-22-2004, 10:47 AM
Nice #'s
I like the torque..
Ryan02SS
10-22-2004, 12:57 PM
Very Sweet. Those torque numbers are insane. I've also noticed how the AFR's really seem to come alive in the 3500-5000rpm range compared to a stock ported casting.
Krazy98Z28
10-22-2004, 03:22 PM
sounds like AFR's are starting to shine. Great numbers
eb02z06
10-23-2004, 10:52 AM
What was the final CC of the heads and what thickness of gasket did u use-BTW very impressive-enjoy!
black_z
10-23-2004, 03:46 PM
Exactly what I was thinking John, very impressive #'s. :drive:
Louis
10-23-2004, 06:30 PM
The AFRs have always been a shining head, but people just slap combinations together that have no rhyme or reason coupled with improper tuning, the wrong cam no attention to detail and wonder why it doesnt make power.
The heads are at a ~ 61 cc + a little thinner gasket, not much.
I sent another AFR headed car to Speed Inc with a smaller cam, no ported TB, LS1 block, Dynatechs, Borla, and a 12 bolt with 4.10s that spit out 438/416. It would be 450 with a new MAF and ported TB.
2 AFR/LG combos go to Speed Inc in one week and make power. There is no mystery here, just proven combos :)
WAHUSKER
10-23-2004, 06:42 PM
Dang, 50rwhp over the previous setup that had a cam already.....that is a LOT more impressive than the results on their webpage with the 224 cam!!!
RutanZ28
10-28-2004, 01:54 PM
What impresses me most about this car is not the power. I drove the car a couple days ago, and with that big of a cam and heads, I was expecting at least *some* drivability issues, however it had none. It drives like a stock Z06. Well, stock that is until you dip into the throttle a bit, at which point it becomes quite obvious that it is not stock at all. Most enjoyable daily driver I have ever been in. As for the power, it is just awesome. With the stock supercars on there, traction is a bigger issue then one would think until you're into triple digit speeds. All in all the car is plain bad ass and a lot of fun to drive.
pdd
10-31-2004, 07:48 PM
very nice :devil:
