Problem after G5X3 Install
Old 10-21-2004, 08:50 PM
torchedZ's Avatar
Default Problem after G5X3 Install
I installed a G5X3 cam in my Z06 over the weekend and had it dyno tuned yesterday. I'm running LG headers with cats and all the bolt-ons. I pulled a dissapointing 363 rwhp and 330 ft-lbs tq. So I found the problem today and it turns out that cylinder #8 was dead. The pushrod had come off the rocker arm so one of the valves was close up all the time. So my car was tuned on 7 cylinders. Here's my problem....
The car runs terrible now and is sluggish. I drove it one mile down the road and pulled over because I smelled smoke. It turns out my cats were cherry red I let it cool down and drove it home. When I got here the cats were again cherry red. I know cats are supposed to get hot, but not that hot. Something is definetly wrong. What gives?? Any advice?
Old 10-21-2004, 08:57 PM
2000Blackout's Avatar
Did you retune it after you fixed the #7?
Old 10-21-2004, 10:21 PM
IntenseSS's Avatar
360hp and 330ft-lbs is great on 7 cylinders.....Alot of people don't make that power with 8 cylinders
Old 10-21-2004, 10:27 PM
ss rally red's Avatar
Sounds like that cats were full of fuel from no combustion in 1 cylinder, what I cant figure out is how your tuner didn't notice you had 1 dead hole......
Old 10-21-2004, 10:31 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Its running really lean now that you have all 8 cyl.If it was tuned on 7 cyl and afr was tuned that way. Add about 11% more fuel for the dead hole and it will be close.FYI you need to redyno tune with widebands to make it right.
Old 10-21-2004, 10:39 PM
cyphur's Avatar
Personally if you can get a cheap tow to the dyno tune thats what I'd do....I wouldn't run a motor that is that out-of-tune.
Old 10-21-2004, 11:08 PM
WS6snake-eater's Avatar
Damn Justin tough break...did you get the oil pressure thing figured out? If you need some help you can always PM me.
Matt
Old 10-21-2004, 11:12 PM
red90cobra's Avatar
Shouldn't be cherry red lol, that's crazy
Old 10-21-2004, 11:44 PM
torchedZ's Avatar
Problem solved! JmX and I had taken the coil packs off twice and the second time I forgot to plug the wires back in on the passenger side I must've been dumping fuel like crazy into the cats. I'm determined to run on less than 8 cylinders, lol. Thanks for all the advice guys....luckily it was something simple.
Old 10-21-2004, 11:46 PM
H82BBad's Avatar
does it feel better with all 8 plugs firing? get it retuned
Old 10-21-2004, 11:50 PM
cyphur's Avatar
dear god man.....
glad you got it figured out tho. next time double check everything
Old 10-22-2004, 01:33 PM
torchedZ's Avatar
Since I was tuned with 7 cylinders am I going to be running lean now that I have 8 cylinders and hopefully an additional 60 hp?
Old 10-22-2004, 01:37 PM
InsomZ's Avatar
let us know how much it puts down now after the tune!
Old 10-22-2004, 01:41 PM
BADSZ28's Avatar
Better change the oil. You just dumped alot of fuel into the cylinder without spark. Some of it went to the exhaust, but a lot is in the oil.
Old 10-23-2004, 06:06 PM
Louis's Avatar
It was making 51 hp/per cylinder, so 60 might not be that far away
Old 10-23-2004, 06:48 PM
Justin called me this afternoon. He has everything running good now, and went back and got a re-tune. The car put down 434 rwhp, and 405 rwtq. I'm sure he'll be posting up the graph shortly. Good job Justin.
Matt
Old 10-23-2004, 07:07 PM
torchedZ's Avatar
Matt
Here's the followup:
https://ls1tech.com/forums/dynamometer-results-comparisons/230604-g5x3-112-cam-only-dyno-results-434-rwhp-405-ft-lbs.html
I actually just got it dyno'd today. I'll go back for a re-tune next month and lean it out a little more.
