Buffing tail lights?
My tail lights had some fading from the sun and minor scratches, i was told i need to buff them with a buffer, does anybody know what else i need to do, as far as if and what cleaning compound/wax i need to use, any help would be appreciated, thanks
TT-TECH Veteran
Yeah it's easy but I would not do it yourself unless you have prior buffing experience. JMO though. I would use 3M clean cut rubbing compound (tan)and then go over it with there perfect it Polishing compound (black) the color refers to the color of the products. The bottles are black.
Copy & Paste Moderator
if you want it done right wetsand it w/2k grit sandpaper then use a mild polish swilrl mark remover w/ a buffer then polish to high. I used Menzerna Intensive polish then Final polish finished off with All In One Cleaner Polish. Ill post pics later if its not too dark.
Ok this is what i did i started w 1500grit then went to 2000 grit. Keeping the surface wet at all times working the paper in a side to side motion. My polishing steps were done with a high speed buffer or rotory. If you dont have a high speed buffer you can use your pc, if you dont have a pc you can do it by hand but it will take you longer.
once all the pieces were done being sanded i used a cutting pad w/ Menzerna's Power gloss which is good for taking out 2000 grit scratches worked very well.
Then i used Menzerna's Intensive Polish to take out any little scratches that could have been left over from the power gloss this was done w/a polishing pad @1500rpms. The last polishing step was w/ Menzerna's Final Polish which adds a nice gloss. I used this w/a finishing pad @1200rpms. I cleaned up the plastic w/ Klasse's All In One cleaner polish (AIO) then topped w/ P21S carnuba paste wax. All in all it took me about 30 minutes w/ the rotory if your using a pc im guessing it will take you about 45 minutes to an hour. If your doing it by hand its probably going to take you ALL DAY. Theres still a little wax here and there but i had to hurry up cause it was about to start raining.
Heres the Pics Enjoy.
My camaro lights where getting bad so being lazy! I had them wetsanded down tell the writting was gone and then all the black lines repainted on and then 2 coats of clear on top. Realy nice but wish I had then smoked out a little a little black in the clear! oh well...
