Just talked to BBK sales dept.
As said above. The guy I talked to said the 85mm intake is pushed back to the end of the year around Jan 05. This freaking sucks. I was holding out buying an LS6 until they atleast produced some dyno numbers. I also asked about them releasing a 85mm matching TB and he said that is in the works, but couldnt comment about it yet. Guess I am going to go ahead and buy the LS6 and wait around for the BBK until I look at the Fast stuff.
The tale continues
Brandon
The tale continues
Brandon
Originally Posted by cyphur_traq
Screw BBK. I'm just gettin a Fast setup this spring.
FAST is a bad *** company, they are definatley better than BBK, BBK is F@%'n expensive.. LS6 is only $300 and u can dip into the 12's...
Good Luck
