MAF ends ?
MAF ends ?
Do the ones you get from thunder racing come with knew bolts or are they the same size bolts as the stock ones. I purchased a set of used ends and did't get any bolts. Also I thought the engraving was on the top if I put mine together it is on the left side. Just wondering if I got a defect. The factory bolts are a tad to big. They will go in about 2 turns
TIA
TIA
TIA
TIA
Originally Posted by Another_User
They sound normal to me. I have never seen a set that came with new bolts. You could easily find some at Lowes or Home Depot if it bothers you. I have a tendency to replace bolts I don't like with stainless ones whenever I get the chance.
