callies rods
Old 10-24-2004, 11:08 PM
kumar75150's Avatar
Default callies rods
I'm thinking bout building a bigger motor that can handle a 300 shot of nitrous.
I have pretty much decided on the Callies crank (engine builder says easier to balance than Eagle), JE nitrous pistons, but am not sure on the rods.
I am thinking I should do more than the standard Eagle H beam rods. Engine builder suggested Callies rods as an upgrade. I havent really heard a lot about them. Should these be good enough to handle 800rwhp or should I step it up to a Lunati billet rod?
As far as other internals, someone mentioned I should use "hellfire rings" for nitrous.
Any other suggestions?
Old 10-25-2004, 04:17 AM
KimberWS6's Avatar
You might want to post this question in the nitrous section.........I know you'll get some good responses in there, and yes I would think the Callies rod should work fine.
Old 10-25-2004, 06:43 AM
SAM98WS6's Avatar
Im was told the Callies rods are the best there is...
I have them.
Old 10-25-2004, 08:15 AM
Super Moderator
Reckless's Avatar
Kumar....my buddy had Callies crank and rods in his turbo motor that made 1150 crank hp. They are good rods.
Old 10-25-2004, 09:29 AM
kumar75150's Avatar
Todd, I'm trying to figure out whether to leave the house or not on these tires.
Old 10-25-2004, 09:55 AM
cyphur's Avatar
Todd how much more expensive are Callies cranks than Eagle? Say for a 4" stroke.
Old 10-25-2004, 12:09 PM
Sweet Cheeks
Damage Inc.'s Avatar
About $650
Old 10-25-2004, 01:14 PM
JZ'sTA's Avatar
The Callies rods are very good rods.
APE uses them quite often and really like them.
Old 10-25-2004, 01:48 PM
Under criminal investigation for fraud
Chris@AP-Engineering's Avatar
Callies rods = very good!! We use them in a lot of engines!
Thanks
Old 10-26-2004, 05:36 AM
10 Second Club + 14 Second Truck Club
antz01ta's Avatar
i have lunati billet's in my motor, but imo Carillo are the best rods out there only problem is the $
