Egr - Pls Help
Old 10-25-2004, 01:17 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
Default Egr - Pls Help
Hello all. I have searched the site and the web and found no satisfactory answer to my dilemma.
okay so my engine sounds like it is hissing out air. I am inclined to believe it is the EGR. I know what it is, but not where ti is or how to replace / delete it as many of you have done. please talk to me like I am a 3 year old and explain precisely what I need to do in terms of finding it, and either re-sealing it, or deleting it. ANY AND ALL comments welcome. I am at my wits end driving down every single street is such an embarrassment at this point. Cant even hear my magnaflow anymore b/c of the hiss. MANY THANKS IN ADVANCE!
brad
Old 10-25-2004, 03:46 PM
RIP April 14, 2008
bumpity
Old 10-25-2004, 03:52 PM
OnyxY2KSS's Avatar
hiss huh? dont know if its the egr, maybe its the air system, but if you wanna check it its right here
if you want to get rid of it there are detailed instructions here
http://www.installuniversity.com/
Old 10-25-2004, 03:55 PM
santino04's Avatar
http://www.installuniversity.com/ins...sity/index.htm this will show you pretty much exactly where it is and how to remove it. Once you do remove it you will need to have purchased the block off plate in advance for the header. Simple as that, a few bolts it comes right off and ur done. You may throw an engine light but it will not hamper performance, you will need to have it deleted from your pcm from a local tuner, or I think you can do it with a power programmer. Good Luck
Old 10-25-2004, 04:25 PM
RIP April 14, 2008
thank you sir
Old 10-25-2004, 04:41 PM
RIP April 14, 2008
what do you mean it could be the air system? the silencers? I dont know its like a steady one pitch loud hiss noise but more so it sounds like "sh" very loud rather than "ss" in hiss. I am stumped...
Old 06-18-2005, 11:08 AM
magnanpi's Avatar
did you ever fix this? i have the same problem...except i idle like ****, barley start, and run lean as hell
Quick Reply: Egr - Pls Help
