Heat shield rattle
Old 10-25-2004, 05:41 PM
Nightfall's Avatar
Default Heat shield rattle
I am going crazy!!!
The heat shields on the back of the car for the muffler and over the axle pipe are making a noise like no tomorrow. The sound is actually like metal rubbing together, a loud chirping. I know it is the shields because I can put pressure on them and it stops. I have tried everything short of removing them to quiet them down.
Can I actually remove them and not worry or should I leave them and keep fighting the good fight until the noise stops? This is my daily driver so, I don't want things getting too hot back there!
Old 10-25-2004, 05:51 PM
2FAST4U's Avatar
I don't have any heat shields anywhere and a dumped exhaust! But for you see if the exhaust can be flexed out of the way by unbolting the clamps and twisting it tell it looks better! On a 98" there should be a metal gas tank so the heat shouldn't hurt anything but that is gas and I wouldn't try it!
Maybe the shield can be "flexed" with a BFH!
Old 10-25-2004, 11:41 PM
Hayze's Avatar
i had the same problem and all i did
1. find and mark the spot where rubbing is happining
2. remove heat sheild
3. pound the marked spot with a hammer to reshape the spot further away from the spot it is touching
4. test drive
I havent heard a noise since then, good luck
Old 10-26-2004, 08:21 PM
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
4. test drive
That sounds like a good method. I wouldn't remove any heat shields unless you absolutely had to do so.
You can fix anything with a hammer.
Old 10-26-2004, 08:29 PM
Hayze's Avatar
sorry, it should be refined...
1. find and mark the spot ( on the heat sheild) where rubbing is happining
3. pound the marked spot ( on the heat sheild) with a hammer to reshape the spot further away from the spot it is touching
4. put heat sheild back on
5. test drive
( repeat steps 1-5 it it continues)
Old 10-26-2004, 08:42 PM
superchannelkev's Avatar
5. test drive
Thanks for the info.. i still am having a little problem here and there.. mostly just flexed my exhaust.. tightened the clamp etc.... thanks again
Old 10-26-2004, 11:22 PM
Hayze's Avatar
Your welcome. I had the same issue and it is the worst noise possible. It drove me insane for days and days.
