Lifter replacement.............
Old 10-25-2004, 08:14 PM
fastbasser's Avatar
Default Lifter replacement.............
Is there an easy way?? Or do the heads havre to come off??
Thanks in advance for the help..
Old 10-25-2004, 08:46 PM
DaddySS's Avatar
Heads have to come off.
Old 10-25-2004, 10:55 PM
Z28Venom's Avatar
Heads definitely have to come off of the car. Start the job on a Fri, and I'm pretty sure you could be finishing it up on Sun... that's if you take your time.
Old 10-25-2004, 11:00 PM
JimMueller's Avatar
Hmm, I guess they wouldn't HAVE to come off, you could pull the cam and hope they fall into the oil pan. Good luck getting them back in, though
Old 10-25-2004, 11:10 PM
blacktransam's Avatar
with a really long penmagnet... LOL j/p
Old 10-25-2004, 11:26 PM
92CamaroReallySlow's Avatar
O...and have fun getting all the gasket material off the heads and block, its a joyous time...
Get some gasket remover (stuffs crazy when you light it on fire, do it in the day time youll see), degreaser, and alot of rags.
Old 10-25-2004, 11:35 PM
car guy's Avatar
a ring of duck tape on the piston and cylinder wall is a good way to keep trash out of your engine, after the scraping is done u can use a shop vac to suck out most of the trash
Old 10-25-2004, 11:36 PM
JimMueller's Avatar
I don't think getting the gasket material off is as tedious as getting all the crap out of the bolt holes. I use a plastic ice scraper to get the big stuff, and a carefully applied razor blade for cleanup.
If you have room, leave the bottom bolt's in a tad so when you pull off the heads less coolant will get in them.
Old 10-26-2004, 08:21 AM
fastbasser's Avatar
I have swapped the heads twice. I know the fun involved in taking the heads off. Yes, getting the gasket off is also a pita!!
I doubted there was an "easy way", but figured one of you guys may have a "secret way" I didn't know about.
Bummer,,,,,,,,,,,,,,, just when it was runnin good..
Thanks for your time..
