Need a tune but dont know where to start??
You can look at the mods in my sig to see what I have. I also want to get the 02 & up Z06 MAF. I read somewhere that I need to get the MAF table for it. I really dont know what the tables mean and where to get them. Some of the obvious things I need a tune for are as follows, The MAF when I get it, and the T/R MAF ends, the bigger injectors, The MTI P/P TB, the catalytic area since they have been deleted. I have the simms but I hear you still need a tune and they can also just delete the rear o2 codes while doing this. Also my custom cold air intake (pics below) Thats about it I guess. Also my car seems to be running rich. The tail pipes are coated black with in a couple days. This was even before adding the bigger injectors. Also one more thing ever since I removed my cats if I leave the car running in neutral for a while like say I'm in the store for 5 min. when I go to back out of the space I give it a little rev and I will see smoke make i'ts way up to my passenger window.
This is only when it sits running. I have had a friend follow me while I got on it and reved it and he did not see any smoke at all and it only does it that one time while you are backing out(been sitting running) if you rev it again there is not any smoke. I also basically need to know what to ask, how to be prepared and what to make sure gets done while I'm getting this tune. I will be using Jeff Creech at carolina auto masters if anyone that reads this has had expierience with them let me know.
TIA,
Shane
TIA,
Shane
I also forgot to mention that the car pops like crazy when you let off,(decel,downshift,or after a hard rev.) I have heard that this also is a sign of a rich condition. I had the exhaust looked over for leaks already.
Moderator
The Delphi 85mm MAFs are a one-piece design and you
can't use the MAF ends on them (the MAF is bigger than
those ends anyway).
Call your tuner up and see if he already has the Z06 MAF
table. I believe I've seen people from that outfit post
here before. They should be pretty clued in.
those ends anyway).
I just don't get why people install bigger injectors w/o tuning for them right then and there. Its not something that you can shift around. Plus you always run the risk of washing down the cylinder walls if you go too rich. This isn't necessarily directly specifically at you, Shane, but just in general, cuz I've seen a few ppl do it lately. I just don't get it.
Did you change the size of the intake to the Throttle Body.
In designing the C5 GM engineering did a ton of testing and from that wrote adaptive strategy that made assumptions as to air and fuel flow under different engine conditions. Changing those airflow parts, esp larger ones reduce the velocity and the A.S still functions as if the stock parts were being used and how it was programmed and does not change even with minor tuning. Most cases when the gas pedal is lifted and goes into decel with the larger airflow parts confuses the PCM and is adding or removing fuel when it really did not have to.
LS1Tech Sponsor
Lets start with the simple things..There is absolutely no gain switching out your stock mass air meter.From what it looks like you took out your 26lb injectors and put in 28's.The computer should be able to compensate for that without much problems,but the MA is killing it without tuning.
OK, you think I'm ok with those injectors. I have not purchased the MAF yet so it shouldn't be killing anything. I heard that the Granatelli MAF was not worth getting but I did not realize the ZO6 MAF was worthless as well. I plan on getting the LS6 intake in a couple weeks so I will wait to get the tune before I get that. I figured with the LS6 intake and injectors you should get the MAF as well but I guess not, thank you. My car is definately rich is there any other way to fix that without a dyno tune.
