New LS1 Owners - Newbie Tech - Rattling in hatch area???
View Full Version : Rattling in hatch area???
JHTZ28
10-26-2004, 08:53 AM
Well this has been driving me crazy for several months and I've decided I've had enough. Everytime that I hit a significant bumb (pot hole or speed bumb) a loud rattle or clanking sound comes from the rear hatch area. I'm not sure if it's the hatch itself or something else. I did not notice this until after I had my SFCs installed. Has anybody experienced something similar to this? Any ideas? It always seems that it's the loudest when I have a passenger (go figure), unrelated to the problem (I think), but it's emabarrassing for sure. Anyways, if anybody has any suggestions, please post up b/f I resort to taking it to the dealership.
Thanks,
JHT
hourang
10-26-2004, 09:10 AM
check your spare tire. also try the hatch release spring mod.
rustylt1
10-26-2004, 11:21 AM
Yeah, check the latch in the hatch. Mine's been rattling for a while now and I can jiggle the whole thing from side to side. Haven't got round to fixing it yet as it involves removing the rear hatch trim.
TheBlurLS1
10-26-2004, 05:19 PM
my damn seatbelts were rattling around. i slid them down and tucked them in the back seats, looks cleaner too!
QuickSilver T/A
10-27-2004, 05:47 AM
Can someone tell me about or post a link to the "hatch release spring mod" ?
TA TED
10-27-2004, 07:04 AM
Adjust the hatch release mechanism. 2 bolts and slide it down until it tightens up.
luvmeZ28
10-27-2004, 08:09 AM
as already stated, maybe your spare is jumping around, or maybe the jack came loose and is jangling around.
jimmyblue
10-27-2004, 08:40 AM
My Panhard mount bolts were slightly loose and the
bar made a clicking / clunking sound that I was sure
came from inside the trunk. Only bouncing the car from
below, rear wheels on ramps, let me find that sound.
hourang
10-27-2004, 10:12 AM
www.installuniversity.com
install documents, under miscellaneous, rear hatch release fix
VeitSSki8701
11-25-2008, 12:00 PM
my center mount exhaust cracked in the little center piece from body twist and rattled so bad i had to duck my head down and cover when i pulled in a parking lot. SO EMBARRASSING! I said forget this and grinded the bitch down. no more buzzing.
SmurfLSX
11-26-2008, 12:15 PM
i also vote for the spare tire. happend in my car
Blacklightning744
11-27-2008, 01:37 AM
could be the spare tire as already stated, i however installed slp subframe connectors on my car and the noise went away.
vtirocz
11-28-2008, 11:53 AM
JHTZ28,
In your post, you said you noticed it after installing SFCs. Not sure which type of SFC you had installed, but if the rear lower control arm bolts were taken out and reinstalled when installing the SFC, I would check that first to make sure they are set to the proper torque.
After I had my BMR boxed SFCs installed, I noticed a clanking/rattle noise and the rear lower control arm bolts were the culprit.
AznMuscle
12-01-2008, 11:02 AM
I would say spare tire also. I have that problem, but just have been to lazy to fix it lol.
TXZ28LS1
12-01-2008, 03:53 PM
my rear hatch always had some type of squeaking sound. not really rattling. it got very annoying.
SweetSolace
12-01-2008, 06:09 PM
my spare tire rattled around for a while so i just pulled out out. now i have 4 12's walled in where the back seat use to be... so pretty much every thing rattled before i dynomatted the whole car >.< rawr!
IZRED
12-01-2008, 06:17 PM
It might be your spare tire/jack, if so, just wrap an old T-shirt around your jack.
Joshu
12-01-2008, 07:00 PM
That's what I did. The sound was a loud metal KA-CHUNK.
allbaugh_04
12-02-2008, 10:13 AM
Make sure t-shirt is a "small" size or polysester to cut down on weight.
johnLs1camaro
12-02-2008, 10:51 AM
^^haha smart thinking!!
kbras12
12-04-2008, 09:03 AM
I got a clanking noise in my right rear when i hit any kind of bump but im not sure what it is. The car still has the original shocks that could be it
