How hard is it to change rod bolts?
Old 10-26-2004, 10:27 AM
LS1TECH Sponsor
Steve Burger's Avatar
Default How hard is it to change rod bolts?
I may attempt this in my garage based on feedback from here. Also what type of bolts would you recommend and why? Where would I attach an engine hoist to support the engine?
If I do this, I will do it the same time I swap the K Member.
Thanks for any feedback.
Old 10-26-2004, 10:32 AM
Bo White's Avatar
I would run the ARPs- either grade, if you can change an oil pump in an old chevy and can read a torque wrench- you can handle it.
Old 10-26-2004, 04:13 PM
ArKay99's Avatar
I did it with the ARP Pro's. No issues. However, if I were to do it again, I would use the Katech bolts. They are a little pricier but, they are the same length and weight as the stock bolts so, no inbalance issues. And the torque sequence and amount will not distort the rods. Mine didn't distort any that I could measure, however there are some that have measured and found out-of-roundness.
Old 10-26-2004, 04:45 PM
Bryan TTM's Avatar
ARP...you can do it...drop the oil pan...rotate the engine to each rod, you can do two rods at a time...look at the rod bearings when you do it
Old 10-26-2004, 11:13 PM
9 Second Club NA
Dragaholic's Avatar
So you can change the rod bolts without taking the engine completely out of the car???!!!
Old 10-26-2004, 11:16 PM
SSean's Avatar
I swapped 8 sets of rod bearings and 4 sets of main bearings with out taking the engine out of the car (yes I know there are 5 main's, but I couldnt get the main cap out of the back of the block with out removing the rear cover....with out removing the tranny, and all that wasnt about to happen ) so yes, you can do the rod bolts
Old 10-27-2004, 12:01 AM
rons 00z's Avatar
are you guys dropping the k member at all?
Old 10-27-2004, 12:47 AM
SSean's Avatar
I completley removed my k-member, yes. I belive some guys are just lowering theirs though
Old 10-27-2004, 07:28 AM
LS1TECH Sponsor
If I do this I will be changing the K Mimber at the same time. I thought the process was to remove and replace ONE bolt at a time. To look at the bearing I would need to pull the cap apart.
Is that what's being suggested?
Old 10-27-2004, 08:29 AM
Bo White's Avatar
If inspecting the bearings is the game plan then remove the cap, but I just do 1 at the time so to not disturb anymore than you have to. Besure to retorque the bolts as suggested by ARP or what ever company you go with.
Old 10-27-2004, 11:59 AM
9 Second Club NA
Dragaholic's Avatar
So the k-member has to be dropped or lowered to swap the rod bolts? What if I have the BMR k-member in there? Whats the purpose of dropping the k-member, is it to take the pan out or to get to all of the rod bolts? Im really thinking about changing them out but dont wanna drop the k-member to do so. I figured since I had a tubular one that there would be enough room. Thanks.
Quick Reply: How hard is it to change rod bolts?
