What is the best ls1 cam ?
i know it is an old issue but i really want an answer !!
fellows i need help , i contacted MTI asking them about the best cam pushrods springs retainers formula for a stock ls1 heads ... the surprise was G1 ? their G1 is 228/232 , 575/588 113 with pushrods , springs and retainers ..?
what do u think ??
well, i think it is 2 big for a stock heads ..? and the engine will suffocate ?
my friend tried an 580 cam ... i laughed when i saw his performance , it was nothing just to much noise without any acceleration ...
i checked comp cam there were plenty and variety of cams .. donno what to choose for my stock 200 intake heads ??
one guy advised me to get G5X2 cam ?? what is this cam ..?
guys tell me about ur experience ... advise me !! dont forget fo a stock ls1 heads ...
what do u think ??
check out the futral cams.. a lot of people are putting down great numbers with them.. i just got mine in and its awesome.. i am untuned though so i'm not getting the full potential.. just search on futral cams and check out the numbers people are putting down on Cam only cars.. tons of people over 400RWHP! good luck
Originally Posted by MNR-0
We have 230+ cam only cars in OZ (stock heads) and all the bolt-ons running 10s passes.
I think thier answer is a good one, you might want to go bigger depending on your setup, or smaller depending on what you do with the car.
Originally Posted by FiveSevenEagle
what is ur cam numbers ..? lift duration lobe .. etc
and the F13 (230/232 .595/.585 112LSA) - I think that is the correct spec on the F13, check the website to make sure. He also offers a variety of custom grinds and can grind both those cams on a 113 or 114 LSA, however the idle and driveability with the 112 is VERY good. www.futralmotorsports.com
see cam spec in sig. im made 398rwhp and 375rwtq. i added a ASP pulley and ported TB since then, so i should be a little over 400rwhp. i think that is pretty good numbers on stock heads
ive seen two separate cars dyno this weekend 1 with the gx52 ans one with the 53 they are both stock heads.they went thru a cutout with boltons and put down just over 400 hp I cant argue with those #.I put down 407 hp with a 224.563 on a 114 lsa and a set of ported 5.3 heads.on the same day.
F11 cam specs are... 228/230 .576/.595 114+4... Check futrals website.. its up and running now! bout time eh? haha
What are the other mods to your car? the cam is largely gonna depend on what else is done such as torque converter, M6 and what gearing you have. And at least get headers.
Originally Posted by SMOKIN01TA
well im kinda biased on this answer but i like my cam the best, i put down number in sig with a 12 bolt 4.56 gears on 28" slicks so im probably puting down about 450rwhp and 410rwtq cam only at the moment on a stock rear.
sorry but what is TRex ? what company ?
