Starter wire connections
Old 10-27-2004, 08:42 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Default Starter wire connections
Does anyone have a diagram of which wires connect to which terminals on the starter? I forgot to document that when I pulled the motor
Keith
Old 10-27-2004, 09:07 AM
WILWAXU's Avatar
It's pretty straight forward.
Small one on the small post.
Big one on the big post
There is also a ground wire that goes to the block.
Old 10-27-2004, 09:12 AM
ls1290's Avatar
With my C5, I have five wires and three posts( one small and two large ). One of the wires is obvious that it goes to the small post. The other four I have no idea.
Keith
Old 10-28-2004, 08:28 AM
ls1290's Avatar
ttt.....
Old 12-07-2004, 11:52 AM
2004tr's Avatar
I guess you have managed to sort out.
Seems that the lower large 8mm terminal post has Battery positive with 3 positive feeds out to harness.
The upper large 8mm terminal post is earthed to engine block and the small 5mm terminal post is purple starter solenoid wire.
Confirmation would be appreciated from anyone please.
Thanks Trevor
Old 03-24-2005, 12:20 AM
JoeDirt's Avatar
Meee too !!
Big power to big post on starter
Big ground to block
Small purple to starter small post
small black to ground on pass side frame rail
Now I have 2 left , both red and both say "fuseable link on them "
Did you get this figured out ?? Oh yeah its a 2001 Z06 , not Fbody so I have the 5 wires
Old 03-24-2005, 12:24 AM
Green Thunder's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/294923-anyone-know-where-big-main-ground-wire-goes.html
Quick Reply: Starter wire connections
