Dynamometer Results & Comparisons - TTP S3 AFR H/C Package Results on 03 Z06
TTPMatt
10-27-2004, 09:49 AM
2003 Z06
Mods are as follows:
TTP Stage 3 AFR 205cc Heads - Finish Ported/Polished by TTP
TTP Equalizer V.2 Camshaft
Stock 346ci
Stock LS6 Intake
Stock Throttle Body
Kooks 1 3/4" with 3 x 2 1/2" OR X-Pipe
Borla Stinger Exhaust
Meziere Elec Water Pump
SVO 30lb Injectors
Volant Cold Air Induction
http://www.ttperformance.net/dyno/ttphc_z06.bmp
JS
10-27-2004, 10:07 AM
Very impressive guys.....
Throw a LSX/90 MM on her and u might hit 490 :eek:
PHANTA-Z
10-27-2004, 10:22 AM
Bad-ass. Very nice tune on that one too, who ever it was that did it. I agree with ^^^^ , LSX/90mm would probably pick that one up a good bit.
BADSZ28
10-27-2004, 10:30 AM
What is the CR? Were the heads milled? What are the specs on the cam?
Great numbers btw.
xfactor_pitbulls
10-27-2004, 10:36 AM
Damn.........those are some wicked numbers. AFRs are in my future for sure.
Brandon
slo-vette
10-27-2004, 11:32 AM
That is very impressive! Keep up the good work :cheers:
TTPMatt
10-27-2004, 11:44 AM
Unmilled AFR's.. Compression is about 10.22:1!
You can ask JS about the cam specs... hehehe. They are not public information.
JS the owner would like to do the intake. We saw 22rwhp from the intake on our cam only car, now add in the extra flowing heads, etc. I'd like to see what the lsx makes on this car.
OWENMUSTANG
10-27-2004, 11:45 AM
what are the specs on the v.2 cam...
hey, another 470HP afr test in a vette.....not even on tony's dyno :chug:
MaximusPrime
10-27-2004, 11:49 AM
How does the car idle? Is it streetable?
Very nice numbers
BADSZ28
Unbeleivable! Imagine with 11:1 with 90MM LSX! Easily would clear 500rwhp. And still on pump gas and streetable. Sick!
TTPMatt
10-27-2004, 12:25 PM
This is the same cam we have used for a while. It idles with the a/c on max blast, no stalling issues. We do recommend a 3.73 or 4.11 gear for a stick car and automatics need an aftermarket converter.
Bads: Thanks. Yes we will be putting the LSX on soon!
BADSZ28
10-27-2004, 03:30 PM
If I were the owner after spending all that money, I would have said "f it, mill 'em." Was flycutting needed? How about with milled heads? Sorry for all the questions on different posts.
TTPMatt
10-27-2004, 04:10 PM
We would recheck clearances when we do mill the AFRs. I don't want to say yes no or otherwise without knowing 100%
BLASTER
10-27-2004, 05:44 PM
Awesome numbers Matt. Was flycutting needed with the the AFRs in their unmilled fashion? How much do you take out of the ports? Do you just clean them up? Thanks
David Gordon
10-29-2004, 06:32 AM
Makes me wish I would have spent my stroker money differently.
TTPMatt
10-29-2004, 10:51 AM
David: I'm sure your stroker is a nice package though. We did a 395 that made 509/471. We're now doing a set of AFR 225's on that car so it should be even more of a beast.
Worm
10-29-2004, 12:07 PM
Nice #s. Is the 'stock throttlebody' not even ported? Its kinda lean isn't it?
TTPMatt
10-29-2004, 12:49 PM
The final tune was at 13.1 AFR, this tune was at 13.19, not much difference. The stock throttle body is 100% untouched.
Worm
10-29-2004, 03:51 PM
13.1 on the dyno = High 13s on the street right? Thats kinda lean IMHO.
ty_ty13
10-30-2004, 11:56 AM
2003 Z06
Stock 346ci
Stock LS6 Intake
Stock Throttle Body
SVO 30lb Injectors
is your equilizer v.2 cam for sale or what?...i you cant tell the numbers then how can you expect us to flow match, converter match, intake match, and gear match?...it looks very interesting to me especiall because of your lack of bolt-ons...no lsx 90 tb or intake underdrive pully...and the 225cc aren't on there!! im getting a lil excited
TTPMatt
10-30-2004, 01:22 PM
The Equalizer cam is only for sale in house. We keep it exclusive for our inhouse customers. There are only 11 public equalizer cams out there on our customers cars. Unfortunately if you want to buy the package without installing with us, I'd have to sell you a different cam (I'd recommend the G5X3 and we are a LG vendor).
- Matt
Worm
10-31-2004, 02:31 AM
Do you have to flycut? Or is that a secret also?
ty_ty13
10-31-2004, 09:12 PM
- Matt
so if you install it then we can buy it? and what do you mean by only 11 public equalizer cams....
Yellow03ZO6
10-31-2004, 11:01 PM
Matt and the guys at TTP did an excellent job on my 03 ZO6.The car is a beast. If your looking to get work done to your car i recomened them strongly. I will be taking my car back to them to get the lsx intake and 90mm t/b within the next month. The car runs excellent, it doesnt stall, starts right up not to mention it sounds real mean.
Matt dont forget my TTP sticker for the windshield if you have white or yellow ill be back up there to pick it up soon.
TTPMatt
11-01-2004, 12:08 PM
I forgot to give them to you the other day. They are sitting here waiting for ya!
InsomZ
11-01-2004, 12:10 PM
TTPmatt sent u pm bout the AFRs!
