Broken wheel studs?
Easy to change....pull off the caliper, and the rotor. Smack the broken stud with a hammer until it falls out the back of the hub. Insert new stud from back side of hub, and install a stud installer. If you dont have a stud installer, use a lug nut. Tighten down with a impact or by hand until it stops.
