Emblem question
Use a heat gun (hairdryer) to heat up the glue then take some fishing line and it should come off fairly easy. Then spray some adhesive remover to clean up the glue thats left on your car.
Your paint will be fine as long as you clean it all off and make sure to wax the area as the adhesive remover will also remove the wax. I use paint thinner in these situation for years with no troubles!!
