16's and 17's ok?
Old 10-28-2004, 10:11 PM
Alex Beavers's Avatar
Default 16's and 17's ok?
I have a set of 16" zr1's currently on my car, and I am wondering if I can purchase a pair of 17x11" zr1's to put on the back with some 315's. Will this cause problems? I wouldn't be running these all the time, but its a good hour to the closest track so I would be driving on them. Thanks for any replys. Alex
Old 10-28-2004, 10:45 PM
Slammed-am's Avatar
I think that would be sorta cool, as long as the rims match.
Old 10-29-2004, 02:05 AM
I'm not really worried about the looks, i just would like to know if it will cause problems with my ABS or my traction control.
Old 10-29-2004, 01:50 PM
Xsta Z 28's Avatar
As long as the overall diameter of the tire is the same you'll be fine.
Old 10-29-2004, 03:24 PM
2MuchRiceMakesMeSick's Avatar
If there is a difference of 10% in circumfrence between your front and rear wheels your ABS will freak out. Just something to keep in mind.
Old 10-31-2004, 08:18 PM
ssmaro's Avatar
ha doutful man, when you hit the breaks it would shutter like crazy
Old 11-01-2004, 09:36 PM
I think it would be ok. With the tire calculator it shows an over all diameter difference of my 16 inch tire being 25.65 and the 17 inch being 25.68 thats only .03 difference, and -.95 revolutions per mile difference. Would one revolution per mile really make that much difference? I have ran 245 and 255 on the back with nothing wrong. Any opinions?
Old 11-02-2004, 05:54 AM
I highly doubt 0.03 inches will make a difference. You probably wear that much from a good burnout. Now that is assuming that your tire calc is correct.
Old 11-08-2004, 11:45 PM
ssmaro's Avatar
Yeah your tires would be alright in this process but lets talk about your ABS. Basicially since your rear wheel is moving/spinning faster than your front wheel when you hit your breaks only your rear breaks would actually be slowing your down. Get my drift or shall I explain it more technicially?
Old 11-08-2004, 11:53 PM
As long as the circumfrence between the front and rear tires is less then 10% there is no problem with ABS
Old 11-09-2004, 12:02 AM
The Sad's Avatar
Is 10% the for sure magic number? I have heard 5% before. I am wonder if anyone knows for sure, because I would like a taller tire in the rear.
Old 11-09-2004, 07:54 AM
JackZ28's Avatar
You could always have it reprogrammed, or do it yourself with Edit software.
