what are the best heads and cams for ls1's?what are the prices?
Couldn't tell you what the best H/C packages are, that's relative. But as far as pricing:
Cam only $300-400 new
Cam package (springs, retainers, pushrods, valve seals, spring seats) $600-900
Heads $1400-2500 fully assembled.
Hope that helps.
Hope that helps.
My ARE stage 2 H&C will be for sale soon... it's worth $3085 and I will be selling it for $1500 in 100% mint condition. I am going with an Iron Block 408 PM me if you are interested!
Comp cams 230/230 112LSA XE-R lobes .592 lift 0 advance
5.3L ARE ported heads 2.02/1.57 valves
Dual Springs (987's)
298cfm @.600 lift intake
228cfm @.600 lift exhaust
227 intake CC's
10.8:1 compression
227 intake CC's
10.8:1 compression
You should also check with MTI Click here They have many time and track proven off-the-shelf set ups and can also provide custom packages per your specs. My MTI heads have put down more power than many of the "other guys" heads even while using a smaller cam.
