stroker vx superstroker - what's the difference?
Old 10-29-2004, 03:30 PM
MeanWS6's Avatar
Default stroker vs superstroker - what's the difference?
I see people mention stroker and then superstroker when talking about the same cubes. What makes it a superstroker or is it just another glorified term?
Old 10-29-2004, 04:14 PM
11 Bravo's Avatar
I guess you could call a superstroker a engine that is bored and stroked. But, yeah, it's a glorified term lol.
Old 10-29-2004, 07:46 PM
someday's Avatar
i would think that an engine with a 4.00" stroke would be a "stroker", while a 4.125" stroke would be a "super-stroker"...
Old 10-29-2004, 07:56 PM
11 Bravo's Avatar
Then a 427 would not be a superstroker Maybe a 436 or 455 would be a mega-super stroker
Old 10-29-2004, 08:00 PM
12 Second Truck Club
Magic Chicken's Avatar
I've never heard the term "superstroker."
Old 10-29-2004, 08:03 PM
02WS6Bird's Avatar
i think the term super stroker has something to do with the power it puts down due to all the top end components-Cam, heads, intake....if its designed for RACING and RACING ONLY its a super stroker i would sya
if its streetable...and astounding at the track its in between...
id consider anything in the 300s still jsut a stroker however and a 400+ super stroker (even the MTI said there 455 will be a very streetable motor with 534 rwhp and 542 rwtq lol)
Old 10-29-2004, 08:11 PM
cyphur's Avatar
I've always heard it used in reference to MTI's engines, they pretty much use the term exclusively. Check it out: http://www.motorsporttech.com/fbody_engine02.asp
Since they coined it, people have started using that term to refer to pretty much anything close to or above a 427.
Old 10-29-2004, 08:33 PM
H82BBad's Avatar
generally a stroker is a 383 or a 395 all stroke engine. What is refered on here as a super stroker is when you add bore. so a 402,408,422,427 some people would only consider the 422 and larger as super stroker since the bore is .200 larger than a 346.
Old 10-29-2004, 09:25 PM
Racehead's Avatar
I guess you would call the 468 in my '71 a stroker then ?
Old 10-30-2004, 12:44 PM
strokedls1's Avatar
Super stroker is just a bore and stroke combo.
